What CPU to buy if I don't intend to overclock?
PostPosted: Thu Apr 24, 2008 11:57 pm    Post subject: What CPU to buy if I don't intend to overclock? Reply with quote
Q9450 or is Q6600 sufficient w/ 8800GT to play high end games in mid to high settings?
iguana
PostPosted: Fri Apr 25, 2008 12:45 am    Post subject: Reply with quote
IMHO, E8400 Smile w/8800GT 512MB
I can't imaging any reason to don't overclock Core2.
My Want List: http://www.cpu-world.com/forum/viewtopic.php?t=22729
Soviet chips info and my own collection: www.cpu-ukraine.com
PostPosted: Fri Apr 25, 2008 3:45 am    Post subject: Reply with quote
I think the Q6600 will be sufficient for most of the current games.
A CPU with 4 cores is always better than a two-cored one!
Although most games don't support the 4 cores (most of them utilize only two), all the background tasks like antivirus, firewall and Windows in general run on these "spare" cores while the game can use the other two exclusively.
If a dual-core CPU like E8400 is used - the game and the background tasks will struggle for the CPU usage.
I use a Q6600 in my PC. A Q6600 can be easily overclocked from 24000 to 3000 MHz, by setting the FSB from 1066 to 1333 MHz Wink
Chiefish
PostPosted: Fri Apr 25, 2008 5:42 am    Post subject: Reply with quote
The Q6600 is sufficient for any new game out, its the Gpu that would be the questin for you. And a 8800GT should do anything you want within reason.
Cobracon
PostPosted: Fri Apr 25, 2008 6:52 am    Post subject: Reply with quote
I beg to differ...........
An e8400 CPU won't be struggling to do ANYTHING, and current versions of BitDefender and Kaspersky use very little processor capacity while running in the background. Also, an e8400 starts life @ 3.0GHz with a 1333FSB.
Current thinking (and there are any number of tests to illustrate this available online) says, and most games currently demonstrate a dual core CPU is as good as or better than a quad core CPU (with equal speed and FSB ratings) when it comes to gaming. Last I checked, the World Record holder for 3DMark06 scores was a dual core Intel CPU.
That's not said to throw a bad light on the q6600, which anyone should be proud to own. Looking to the future, the 'experts' say that more and more new games will utilize the advantages offered by a quad core CPU.
As has already been posted, the GPU would be the real determining factor in game play activity.
The Tom's Hardware website has a section where you can pit 2 different processors against each other and compare their performance based on various popular games and standard benchmarks. These are not opinions, but real life statistics.
karry2008
PostPosted: Fri May 09, 2008 2:49 am    Post subject: need help Reply with quote
'm gonna build my first ever computer myself and really don't know much. I would like it to be able to run Crysis at High settings, 0xAA, 8xAF @ 1280x1024. I don't know if it's possible to do this with the current hardware and achieve a playable framerate though(let say 25+FPS). Right now i'm on XP DirectX9 but i'd really like to move to Vista(32 or 64 bits???) and DirectX10 soon. All i need is a motherboard, CPU, GPU, memory and PSU. I have the rest
karry
PostPosted: Fri May 09, 2008 3:08 am    Post subject: Re: need help Reply with quote
karry2008 wrote:
You can get 5,000 free points to spend on building backlinks to your website. These points will allow you to get free text link ads on up to 5,000 quality websites. The offer simply requires a DigitalPoint forums membership. http://...
Please don't post the advertisement links to commercial sites!
Spammers are not very welcome here.
Cobracon
PostPosted: Fri May 09, 2008 3:20 am    Post subject: Re: need help Reply with quote
[quote="karry2008"]'m gonna build my first ever computer myself and really don't know much. I would like it to be able to run Crysis at High settings, 0xAA, 8xAF @ 1280x1024. I don't know if it's possible to do this with the current hardware and achieve a playable framerate though(let say 25+FPS). Right now i'm on XP DirectX9 but i'd really like to move to Vista(32 or 64 bits???) and DirectX10 soon. All i need is a motherboard, CPU, GPU, memory and PSU. I have the rest
karry
You'll do a lot better with your request if you start a new thread instead of inserting your question onto the tailend of an an existing one.
PostPosted: Thu Jul 17, 2008 5:38 am    Post subject: Reply with quote
http://www.tomshardware.com/us/
register and use their resources, thay have a good forum + lots of articles and howtos...
Hardware stuff isn't that difficult to understand. It's difficult to shape to your own desires.
Cobracon
PostPosted: Thu Jul 17, 2008 8:54 am    Post subject: Reply with quote
tom
Social Media Marketing - 868548704.99088
I'll particially repeat an earlier post, by myself, that is based in fact, and refutes your claim that an e8400 will be struggling to do ANYTHING related to it's job:
"I beg to differ...........
..............Current thinking (and there are any number of tests to illustrate this available online) says, and most games currently demonstrate a dual core CPU is as good as or better than a quad core CPU (with equal speed and FSB ratings) when it comes to gaming. Last I checked, the World Record holder for 3DMark06 scores was a dual core Intel CPU.
The Tom's Hardware website has a section where you can pit 2 different processors against each other and compare their performance based on various popular games and standard benchmarks. These are not opinions, but real life statistics."
PostPosted: Mon Jul 28, 2008 8:37 am    Post subject: Reply with quote
I believe that a simple question is just the occasion to advertise shopping...
Wizzard1
PostPosted: Mon Jul 28, 2008 6:10 pm    Post subject: Reply with quote
Who are all these people, and why do they continue to post advert links?
Cobracon
PostPosted: Tue Jul 29, 2008 2:10 am    Post subject: Reply with quote
It's like listening to only half of a conversation. Think
admin
Site Admin
PostPosted: Wed Jul 30, 2008 1:12 pm    Post subject: Reply with quote
It's probably the same person using different user accounts to promote his sites. All spammer's accounts are deleted.
Admin
martin
PostPosted: Wed Aug 06, 2008 6:28 am    Post subject: comment Reply with quote
