AMD Athlon 64 2800+ / 512KB Cache / 1600MHz FSB / Socket 754
PostPosted: Sun Nov 21, 2004 4:27 pm    Post subject: AMD Athlon 64 2800+ / 512KB Cache / 1600MHz FSB / Socket 754 Reply with quote
can enybody tell me how cool this cpu is?
and what intel p4 to compare it whit?
i need a computer that runs sims2 exelent,will this do it whit a cool vga card?and do this mainbords need other powersupplys then the p4?
something else who is diffrent from this to a p4?
PostPosted: Wed Nov 24, 2004 12:18 pm    Post subject: Re: AMD Athlon 64 2800+ / 512KB Cache / 1600MHz FSB / Socket Reply with quote
Maximum case temperature is 70 degrees of Celsius, maximum power dissipation is 89 W. Power dissipation should be less than that because Athlon 64 3800+ also has maximum power 89W. Strange...
I can't answer other questions because I don't have the Athlon 64... yet Smile
okidoki73
PostPosted: Thu Nov 25, 2004 1:15 pm    Post subject: Reply with quote
hehe by "cool" i dident mean the heat it produce,i just meant how fast it was.
but thanx for the answer anyway Very Happy
gshv:dont u read pm or mail?
PostPosted: Thu Nov 25, 2004 3:09 pm    Post subject: Reply with quote
I'll PM you in a minute.
