Between Core 2 Duo or AMD Turion 64X2
Maite
PostPosted: Wed Jul 23, 2008 1:14 pm    Post subject: Between Core 2 Duo or AMD Turion 64X2 Reply with quote
If I posted in the wrong place, please, move it or warn me Smile
I am about to buy a laptop and I have to choose between these CPU's
Quote:
Core 2 Duo T5200 1.6 GHz 2MB caché or AMD Turion 64 X2 TL-58 1,9GHz 1MB caché
The laptop with AMD is more complete but if the cpu difference is not huge with the Intel I'll go for the AMD.
If you wanna see the laptops (soloprecios.es online shop where I'll buy)
AMD laptop:(spanish)
Quote:
http://www.soloprecios.es/d-HP-Portatil-HP-6715S-2GB-(Turion-X2-TL58-192GB-160GBDVD-RW154VHB)-B031172.html
Intel laptop: (spanish)
Quote:
http://www.soloprecios.es/d-HP-Portatil-HP-530-(FH547AA)-(Intel-Core2-Duo-T5200-1-62GB-DDR2-160GBDVD-RW154VHB)-B032997.html
The AMD laptop is an HP 6715S 2GB (Turion X2 TL58 1.9/Chipset AMD M690T/2GB DDR2/ 160GB/DVD RW/15.4/VHB) with graphic ATI Radeon X1250. 6 cell Lithium-ion battery. With bluetooth.
The Intel laptop is HP 530 (FH547AA) (Intel Core2 Duo T5200 1.6/2GB DDR2 160GB/DVD RW/15.4/VHB) with graphic Intel GMA 950. 4 cell Lithium-ion battery
Thank you for your time Wink
Maite
Wizzard1
PostPosted: Wed Jul 23, 2008 4:12 pm    Post subject: Reply with quote
Go for the AMD. It's extras make up for the processor shortcomings Very Happy
Maite
PostPosted: Wed Jul 23, 2008 4:21 pm    Post subject: Reply with quote
Thanks, I think I also prefer the AMD.
