Seeking CPU Suggestions for Upgrade to My P4 Machine
txstars15
PostPosted: Wed Aug 06, 2008 12:33 pm    Post subject: Seeking CPU Suggestions for Upgrade to My P4 Machine Reply with quote
Hello,
I'm wanting to upgrade for general performance and speed improvements, particularly speed when surfing the web and opening windows or following links. Gameplay is a more minor interest for me.
I was considering the Intel Core 2 Duo chip family or the AMD x64 series, but am not knowledgeable enough on which way to go. I know that the Core 2 series is much more efficient than the older P4's, so CPU speed is not the absolute, end-all factor for speed (or is it?).
What is the current thinking on upgrading with these options? Thanks for your inputs.
Cobracon
PostPosted: Wed Aug 06, 2008 3:52 pm    Post subject: Reply with quote
1st, I'd like to thank you for registering so we can refer to you as something other than 'guest'. Smile At some point they'll have to pick a number to differentiate between themselves.
What motherboard do you have that will be getting the CPU upgrade, or did I misunderstand your post?? Maybe you are considering a new board/CPU/RAM??
