Noteworthy ES chips with unlocked multipliers
crazybubba64
PostPosted: Tue Jul 02, 2019 10:46 am    Post subject: Noteworthy ES chips with unlocked multipliers Reply with quote
Every now and again someone asks "Are ES chips unlocked?", and for the most part, the answer is no.
However, there are plenty of obviously unlocked ES chips, such as the many QS press samples for various extreme editions and k-series parts, but what about the other oddballs?
I've found a few ES chips that are unlocked that aren't marked as such on CPU-World (or just simply don't exist on the site):
    QBDS (CPUID) - Seems to be a theoretical E5-1640? fully unlocked.
    Q1TK (according to HWInfo64) (CPUID) - seems to be a desktop lynnfield chip masquerading as a clarksfield in the PGA988 package running at 1.33-1.6GHz natively, but is fully unlocked (albeit very unstable)
Do you know of any other ES with unlocked multipliers?
My collection
PostPosted: Tue Jul 02, 2019 10:56 am    Post subject: Reply with quote
All post Northwood QS CPU are locked and almost all ES starting from SNB are also locked. That's for the old base multiplier.
For SNB and up, the concept of "base multiplier" doesn't exist anymore from a technical point of view. Ratios are dynamic and based on P-State. The only "lock" (for non-K/X CPUs) removes the ability to set the P-State Max multiplier beyond a pre-defined value.
crazybubba64
PostPosted: Tue Jul 02, 2019 11:09 am    Post subject: Reply with quote
"almost" all being the key phrase here.
And yeah this includes "turbo unlocked"/unlocked p-state chips like the ones shown above.
My collection
PostPosted: Tue Jul 02, 2019 11:24 am    Post subject: Reply with quote
Starting with SNB and P-State control, QS are locked or unlocked according to the commercial counterpart (K/X or non-K/X).
For ES, the same QSpec can be locked or unlocked.
1/ Some QSPEC came factory unlocked (usually ES1) but they can be software-locked later.
2/ Most QSPEC (usually ES2) came factory locked but they can be unlocked (or re-locked) later by software tricks. The unlock procedure is persistent to reboot/power off. Same for cache slices activation. So you can find the same ES2 QSPEC in locked or unlocked state.
PostPosted: Tue Jul 02, 2019 12:49 pm    Post subject: Re: Noteworthy ES chips with unlocked multipliers Reply with quote
All v1/v2 E5-16xx are unlocked so it makes sense.
KK_Fin
PostPosted: Wed Jul 03, 2019 9:16 am    Post subject: Re: Noteworthy ES chips with unlocked multipliers Reply with quote
AFAIK, E5-1603, E5-1607, E5-1620 and E5-1607 v2 are locked. Probably E5-1620 v2 also. Others (with 6 cores) are unlocked (like QBDS).
1242 x86 CPUs in my collection (week 2 2026).
crazybubba64
PostPosted: Wed Jul 03, 2019 9:40 am    Post subject: Re: Noteworthy ES chips with unlocked multipliers Reply with quote
I need to confirm this, but I think the E5-1620V2 is unlocked, as I believe it is a repackaged i7-4820k. The E5-1620 is definitely locked, as the i7-3820 was as well.
My collection
KK_Fin
PostPosted: Wed Jul 03, 2019 10:21 am    Post subject: Re: Noteworthy ES chips with unlocked multipliers Reply with quote
That's logical and makes sense, but I have read reports that 1620 v2 is locked. I don't have v2 CPU so I can't confirm. I have had 1620 "v1" and it was locked.
PostPosted: Wed Jul 03, 2019 11:06 am    Post subject: Reply with quote
Yes, I was wrong about 1603, 1607.
But if 1620 is locked then what is this?
https://valid.x86.fr/ty1zaz
https://valid.x86.fr/iey7ya
https://hwbot.org/submission/2514344
https://hwbot.org/submission/3813172
crazybubba64
PostPosted: Wed Jul 03, 2019 11:22 am    Post subject: Reply with quote
Confused
The mystery deepens...
Maybe it depends on how the board handles the chip?
I'll have to grab some of these from work next time I get the chance and confirm if they are locked or not.
My collection
PostPosted: Wed Jul 03, 2019 12:55 pm    Post subject: Reply with quote
The "lock" is software on ES. It can be locked or unlocked depending of the microcode pushed by the BIOS and/or the use of an internal Intel tool.
KK_Fin
PostPosted: Wed Jul 03, 2019 2:23 pm    Post subject: Reply with quote
Good question and I don't know the answer. I couldn't change the multiplier over 38x (max turbo mult.) on my E5-1620 (SR0LC). If I put K-series i7 CPU on same motherboard, multiplier can be changed.
Maybe there both locked and unlocked chips? Confused It would explain a lot about conflicting reports.
lazyfortress
PostPosted: Wed Jul 03, 2019 5:40 pm    Post subject: Reply with quote
Is the E5-1607V2 locked? SR1B3 @3.00GHz
My CPU List (Trades and For Sale)
wren4777
PostPosted: Wed Jul 03, 2019 5:43 pm    Post subject: Reply with quote
1607 v2 is locked.
KK_Fin, what board/BIOS are you using your 1620 with? It is probably preventing you from overclocking since it is a Xeon. The 1620 is just a rebadged 3820, and should have a multiplier unlocked to around 42x, iirc.
My WTB List
My collection
Have a nice day! Smile
KK_Fin
PostPosted: Fri Jul 05, 2019 6:27 am    Post subject: Reply with quote
linuxfanatic wrote:
1607 v2 is locked.
Board was Asus P9X79, BIOS version probably newest version, but I'm not sure since it was ~2 years ago. But now after reading your post, I might know what's going on. Non-K Sandy i5's and i7's have that "limited unlocked" feature which allow partial overclocking (4/5 bins above max turbo). And as you said 1620 is rebadged i7 3820, it is also partially unlocked and it explains links send by frag_.
I have to some day retest my chip, but so far I'd say that:
1603 locked
1607 locked
1620 partially unlocked
1650 unlocked
1660 unlocked
