Easter egg in Rise MP6 processor
Goto page Previous  1, 2, 3  Next
red-ray
PostPosted: Tue Jun 18, 2019 6:45 pm    Post subject: I added the assembler Reply with quote
PostPosted: Tue Jun 18, 2019 6:53 pm    Post subject: Reply with quote
Thanks. I should be able to translate that to pure assembler in the morning Smile
mtx500
PostPosted: Wed Jun 19, 2019 4:17 am    Post subject: Reply with quote
debs3759 wrote:
Is there any chance that anyone still has the cpuidnz.asm file?
YES!
PostPosted: Wed Jun 19, 2019 5:50 am    Post subject: Reply with quote
mtx500 wrote:
YES!
Perfect! Thank you.
red-ray
PostPosted: Wed Jun 19, 2019 10:22 am    Post subject: Zero the registers Reply with quote
Hi, I see you got the original code and noticed it does not zero EBX + ECX +EDX before doing the CPUID.
I have found that if you don't do this several elderly CPUs return incorrect CPUID information so advise you to zero the resisters before doing a CPUID.
Do you have an mP6 to test your code on?
PostPosted: Wed Jun 19, 2019 10:41 am    Post subject: Reply with quote
Yes, I have at least two.
amadeus
PostPosted: Tue Jul 16, 2019 11:49 am    Post subject: Reply with quote
Is there a possibility that the page http://www.cpu-world.com/CPUs/MP6/index.html containing the info regarding the easter egg may get an update in lieu of placement of the NZ string in eax and the order in which the 4byte easter egg chunks are returned?
It is kinda obvious from your code "red-ray" but maybe it helps to add these hints to the info provided by the interview?
red-ray
PostPosted: Wed Jul 17, 2019 8:00 am    Post subject: Add a commemt and where I can get a Lynx CPU? Reply with quote
I would suggest you add a comment much as I did. I initially tried setting EAX to 'NZ', but it needs to be 'ZN' and I deduced the order from the returned data.
Does it work on the Lynx CPUs and/or does anyone know where I can get a Lynx CPU please?
vmr_
PostPosted: Thu Jul 25, 2019 8:37 am    Post subject: Reply with quote
Think I have both Lynx and Kirin CPUs, earliest I can try will be late August Smile
red-ray
PostPosted: Fri Jul 26, 2019 6:27 am    Post subject: Which OS will you use? Reply with quote
Great Very Happy, which OS will you use? W2K or NT4 would be ideal, but W9X should be OK. >= WXP can't be used at all as mP6 CPUs don't have the CMPXCHG8 Instruction.
Would you like to sell me a Lynx CPU? Wink
red-ray
PostPosted: Sat Aug 17, 2019 5:07 am    Post subject: Re: Windows 2003 on Rise mP6 (Kirin) Reply with quote
I recently swapped the CPU to a Rise mP6 (Kirin) then booted 2003 Server by accident and much to my surprise it actually booted and looks like it runs OK!
I don't know if a virgin install would work as an AMD-K6 3D+ (Sharptooth) was installed when I installed it. Given XP refused to install I suspect not.
If you have managed to get WXP running with a Rise mP6 I would be interested to hear.
Lotosdrache
PostPosted: Mon Aug 19, 2019 11:34 am    Post subject: Reply with quote
Some weeks ago, I tested a DOS programme writen by amadeus and found that the Easter Egg is also present in my Rise iDragon cpu (MP65RPAPH4-Q 500MIPS). So it's likely that it also works with Lynx cpus.
red-ray
PostPosted: Mon Aug 19, 2019 11:50 am    Post subject: What get's reported for the iDragon ? Reply with quote
Lotosdrache wrote:
Some weeks ago, I tested a DOS programme writen by amadeus and found that the Easter Egg is also present in my Rise iDragon cpu (MP65RPAPH4-Q 500MIPS). So it's likely that it is also works with Lynx cpus
Thank you and given this I too suspect Lynx will have it.
I wonder if it's possible to tell an iDragon from an mP6 (Lynx), what does my SIV (http://rh-software.com/) utility report on it's Menu->Hardware->CPUID->CPU-0 panel please?
vmr_
PostPosted: Mon Aug 19, 2019 12:06 pm    Post subject: Reply with quote
Have to dig out my Win98 install and test the Lynx, hope to try it during the week
PostPosted: Mon Aug 19, 2019 1:11 pm    Post subject: Re: What get's reported for the iDragon ? Reply with quote
I made your link clickable
Page 2 of 3
