CPU upgrade A135-S4656
Goto page Previous  1, 2, 3  Next
PostPosted: Fri Sep 03, 2010 11:16 am    Post subject: Reply with quote
If BIOS supports dual-core, than you don't have to replace it with single core. Unfortunately, it's not possible to tell if the BIOS supports dual-core or not.
Maximum FSB frequency is limited by the chipset. If you have 945GML then it's 667 MHz, and the 940GML has maximum 533 MHz FSB.
PostPosted: Fri Sep 03, 2010 11:26 am    Post subject: Reply with quote
Here is BIOS for your laptop:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/download.jsp?ct=DL&soid=2249220&ref=EV
Version 1.20 of the BIOS fixed some issues with T2060, so dual-core CPUs are supported by your BIOS. Also, I found some references on the net that the T5200 will likely work in your laptop.
peddleagain
PostPosted: Fri Sep 03, 2010 11:33 am    Post subject: Reply with quote
OK in Everest it tells me the chipset is Mobile Intel Calistoga-GML i940/i943 Posting screenshot. I haven't looked at youi bios link yet but I have Pheonix V1.9 updated 1-12-09. It was done at Toshiba where they turned on my lojack and won't turn it off unless I pay them. Absolute tells me they cannot find my machine online.
Here's a partial shot of the chipset window in everest.
peddleagain
PostPosted: Fri Sep 03, 2010 11:40 am    Post subject: Reply with quote
I saw some guy had gotten a T7200 or T7300 to work o a A135-S4666 or something like it but I think thats a completekly different mobo. I think he was on CPU world getting advice too.
Here's the page; http://www.cpu-world.com/forum/viewtopic.php?t=12837
It looks like the same chipset but I'm unsure of the mobo
PostPosted: Fri Sep 03, 2010 12:22 pm    Post subject: Reply with quote
According to Intel 945 chipset datasheet, 943/940GML supports only 533 FSB. The 940GML doesn't support dual-channel memory, so your chipset is 943GML. I have no idea if the datasheet is up to date or not. As I said T5200 and T2450 should work, and, if you decide to try processors with 667 MHz FSB then make sure you can return then if they don't work.
peddleagain
PostPosted: Fri Sep 03, 2010 12:39 pm    Post subject: Reply with quote
Thank You
I'm still learning how to read this stuff. So I'm pretty slow.
Your help is much appreciated.
peddleagain
PostPosted: Fri Sep 03, 2010 1:32 pm    Post subject: Reply with quote
Here's the other half of the chipset info from Everest.
It says something about GMA 950
The Intel chipset info only has 940GML not 943GML info.
peddleagain
PostPosted: Fri Sep 03, 2010 1:38 pm    Post subject: Reply with quote
I found the data sheet and you are once again correct Sir.
I will look for a larger 533FSB cpu judt to see if it will make this thing faster.
peddleagain
PostPosted: Fri Sep 03, 2010 1:42 pm    Post subject: Reply with quote
I just found this page; http://ark.intel.com/chipset.aspx?familyID=24679 and the Celeron M450 seems like it would be faster with the 1M cache, 2Ghz, 533FSB
What do you think Gennadiy am I missing something?
peddleagain
PostPosted: Fri Sep 03, 2010 2:22 pm    Post subject: Reply with quote
I've figured it out the 450 has 32bit instruction set the 520-530 has 64 bit instruction set. That's the difference I found.
peddleagain
PostPosted: Sun Sep 05, 2010 11:19 am    Post subject: Reply with quote
I looked at the T5200 core duo 1.6GHz L2 2MB 533FSB and T2450 core duo 2GHz L2 2MB 533FSB and its the same kind of difference, the T5200 has a 64 bit instruction and the T2450 has a 32 bit instruction.
Which one seems best to you?
I have a 32 bit system Vista Home Basic
PostPosted: Wed Sep 08, 2010 9:19 pm    Post subject: Reply with quote
I think the T2450 will be a bit faster than the T5200, but not much because the T5200 is based on more efficient microarhictecture.
peddleagain
PostPosted: Thu Sep 09, 2010 10:06 am    Post subject: Reply with quote
Thank You
peddleagain
PostPosted: Sat Sep 11, 2010 7:32 pm    Post subject: Reply with quote
I got the chip today. Here's a photo
I'll try to install it tomorrow.
Photo didn't post first time.
Second times the charm?
peddleagain
PostPosted: Sun Sep 12, 2010 1:43 pm    Post subject: Reply with quote
Just realized I don't have any Thermal Paste. Does anyone have a recomendation?
I'm guessing its six of one half a dozen of the other.
Nevermiond I went with Arctic Silver AA-1.75G R on New Egg 3 day delivery.
Expect a report about success or failure of the T2450 installation and bootup by 9-16-10
Thanks for the help Gennadiy
Page 2 of 3
