Intel Auburndale QGFK
Goto page Previous  1, 2
wren4777
PostPosted: Sun Jan 27, 2019 9:13 pm    Post subject: Reply with quote
ME is checking the CPU to see if its valid, and disables boot if it isn't. So swapping CPUs wont help. ME is its own processor, in the chipset, that is always on (as long as there is power)
Try using ME_cleaner.
PostPosted: Mon Jan 28, 2019 12:45 am    Post subject: Reply with quote
That is only effective on pre-Nehalem, later chips it can't remove the boot routines of ME which are what handles the processor checking.
wren4777
PostPosted: Mon Jan 28, 2019 1:34 am    Post subject: Reply with quote
Nah it can still disable boot problems with incompatible chips. I did some testing with my QL32 Xeon which can't run on mainstream chipset boards without modding ME.
OP can try setting the HAP bit with Intel FIT but I'm not sure what the success rates of that on nehalem.
PostPosted: Mon Jan 28, 2019 2:10 am    Post subject: Reply with quote
Good to know
crazybubba64
PostPosted: Sun Feb 03, 2019 12:22 pm    Post subject: Reply with quote
I got my hands on another pga989 laptop with a 50-series chipset.
It's an Asus ROG G53J.
I popped the CPU in, and the unit powers up for about 1-2 seconds with the capslock and numlock leds lighting up, followed by the unit turning off.
The fan does not seem to spin when the lights are on, however, when the unit shuts down, the fan spins briefly.
I haven't tried ME_cleaner yet. Do I need the chip flasher in order to write the modified bios, or can I use the Asus flash utility?
wren4777
PostPosted: Sun Feb 03, 2019 7:01 pm    Post subject: Reply with quote
You need the chip flasher. Follow this guide here: https://www.win-raid.com/t4287f16-GUIDE-The-Beginners-Guide-to-Using-a-CH-A-SPI-Programmer-Flasher-With-Pictures.html
You may also have to add the correct microcodes to the BIOS.
PostPosted: Sun Feb 03, 2019 7:12 pm    Post subject: Reply with quote
Don't laptop allow you to update the BIOS using software, the same way PCs do?
wren4777
PostPosted: Sun Feb 03, 2019 8:27 pm    Post subject: Reply with quote
Yes, but flashing the ME region through software is unreliable.
crazybubba64
PostPosted: Fri Sep 27, 2019 9:58 pm    Post subject: Reply with quote
Since I now have all three chips to compare, here's a scan of an Arrandale, Auburndale, and the mystery QGFK.
Looks like it's using the same sized chips as the larger die on the Auburndale. Maybe it was an attempt at making a quad-core in a similar way to the Core 2 Quads? Might have also just been a mech sample.
My collection
qqa
PostPosted: Fri Dec 22, 2023 9:00 am    Post subject: Reply with quote
kmaxzm wrote:
Hello, I am a CPU collector in China. Please forgive my poor English. I also have a CPU like this, and I don't know what type it is. I originally wanted to buy a i7 CPU Q2CZ, and the shop owner was out of stock, so she gave me this one, 3 dollars. I don't have a PGA989 test machine, so I can't test it either. I think it should be a first generation Auburndale i7 CPU, just like i7 Q2CZ.
I am also from China and I have a q2cz am searching for the corresponding motherboard chipset. Coincidentally the original question was also about the display.
My screen suddenly started to go black showing snowflakes, I speculated that it might be a Graphics issue, now I should suspect the cpu.
Page 2 of 2
