value of c4004, c4008 + c4009?
Goto page Previous  1, 2
wepwawet
PostPosted: Thu Apr 13, 2006 1:29 pm    Post subject: Reply with quote
desoldered chips, especially the very old ones, do work.
i did it often with 4116 ram chips, tested them and all were fine.
You may use the photos I have posted here under CC BY-NC-SA license.
PostPosted: Thu Apr 13, 2006 2:41 pm    Post subject: Reply with quote
If a seller states that a chip is tested and working, it would be different, although if gold pins are covered in solder they do not look as good and that reduces the value. If they are tin pins then solder doesn't affect the look so badly, and I would consider a buy if I know they are tested and working. If they are desoldered and untested, then I wouldoffer less than for a socket pull (although I am aware even for a socket pull there is no guarantee that a chip works).
Page 2 of 2
