ramrod
Posted: Sat Dec 27, 2008 11:55 am Post subject: AMD SOCKET A UPGRADE |
I have a Winfast K7S 741GXMG motherboard with Amd socket A. would like to know what is the highest cpu upgrade i can use. it came with a duron 1.8 which i fried recently and it was replaced with a sempron 1.6. the technition said the 1.6 was all he had on hand to get it back up and running. apparently there are others to use. _________________ Semper Fi |
ramrod
Posted: Sat Dec 27, 2008 1:24 pm Post subject: |
| dume wrote: | http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000129
assuming this info correct, you have fsb 333 (sempron fsb), so max cpu should be athlon XP 3000+ 333 Mhz FSB |
you are right...and also one with 400 FSB. now if i could just find somewhere to buy one  _________________ Semper Fi |
Posted: Sat Dec 27, 2008 1:57 pm Post subject: |
If it's 400, than max xpu is Athlon XP 3200+
A 3200+ is very expensive as it is the last upgrade possible, there is little difference with 3000+@ 333, or a 2800+ (not sure on this one though).
Look around for some charts, try "tom's hardware guide", they have a lot of articles to suit your needs, plus handy charts on the right column
Ebay could be the right place.
There are some catches with Athlon Xp and Sempron, as later Semprons are just Athlon Xp rebranded. Look for that too is the above mentioned site (tom's).
There is some stuff to know, but you'll be happy eventually  |
