darkpaw Guest
Posted: Thu Jun 18, 2009 10:09 am Post subject: which of these two CPUs would be "better" |
I'm looking to setup a new home-theater PC, which has a Blu-Ray player in it (running Vista Home Premium on an ATI Radeon 4650 video card), and am down to choice of CPU that fits in the budget for it.
I have it down to two roughly the same price, but with totally different specs. They are:
Pentium D940:
clock - 3.2GHz
bus - 800MHz
cache - 4MB
Core 2 Duo e6320:
clock - 1.86GHz
bus - 1066MHz
cache - 4MB
One has a much higher clock speed, but slower bus. The other has a much higher bus, but slower clock. The caches are the same between them.
Which of these would give the better performance for the system specs I listed up above? |
Posted: Thu Jun 18, 2009 10:56 am Post subject: |
| Core 2 Duo E6320 is faster and produce less heat. |
Posted: Thu Jun 18, 2009 11:12 am Post subject: |
| Absolutely, go for core 2 duo. |
andamus
| Go with Core 2 Duo |
darkpaw Guest
Posted: Thu Jun 18, 2009 12:17 pm Post subject: core 2 duo |
Really? Even with that large of a difference in clock speed?
OK, thanks for the tips. I appreciate the help. |
andamus
Posted: Thu Jun 18, 2009 4:09 pm Post subject: Re: core 2 duo |
| darkpaw wrote: | Really? Even with that large of a difference in clock speed?
Yes Core Duo have a better IPC (instructions per clock) than P4, so it's able to run programs faster even if it has a lower speed. |
Posted: Fri Jun 19, 2009 1:30 pm Post subject: |
That's right brother!
Allelujah! |
