If you buy something through eBay links below we may earn a small commission.
This will not cost you extra, and it will help us to keep the forum
operational and ad-free.
daleakins
Posted: Thu Sep 16, 2010 9:10 pm Post subject: Upgrading my CPU |
I have been trying to upgrade my cpu. I contacted HP and they told me that i had to use "Athlon 64 X2 with Dual Core technology (64 Watt only)". Now, i have looked all over the web for a 64 watt cpu. I can not find one. I did find a 65 watt one. Its a "AMD Athlon 64 X2 5000+ Brisbane 2.6GHz 2 x 512KB L2 Cache Socket AM2 (65 watt) Dual-Core Processor" Will this work. HP says it has to be (64 watt)! Will some one please tell me if it will work or not. If not, can some one tell me which one to get.
Here is the link to the one i was looking to get. http://www.newegg.com/Product/Product.aspx?Item=N82E16819103219
If this will not work, can some one give a link to a cpu that will work, or model number. A BIG THANKS to the guys that help the newbies like me. We have to start some where. LOL. Thanks.
(My PC Specs)
Compaq Presario SR2168HM
AMD Sempron Processor 3400+
Model #: RQ416AA
S/N: CNH70215DP
CPUID information
Update:
I found a cpu that i know will work, but it is over $200. HOLY CRAP!
I was looking to spend $100 dollars at the most. Heres the link, LOL. http://www.amazon.com/AMD-Dual-Core-Processor-64-Watt-ADO5000DSWOF/dp/B000VTQ0Z4[/url]
Posted: Thu Sep 16, 2010 9:42 pm Post subject: |
It's impossible to tell if it will work for you or not if we don't know your HP computer model
daleakins
Posted: Thu Sep 16, 2010 11:01 pm Post subject: |
Ignore this post.
Posted: Thu Sep 16, 2010 11:07 pm Post subject: |
Do you know for sure if the ADO5000DSWOF works on your system? If not then it could better to stay with processors that have the same or almost the same stepping. Your current CPU is probably is SDA3400IAA3CN or SDA3400IAA3CW - both have F2 stepping. To be safe you may want to upgrade to processor with F2 stepping, for example, ADO5200IAA6CS, ADO5000IAA5CS or ADO5000IAA5CU.
Edit: Please ignore the question at the beginning of this post. I posted at the same time as you did.
Posted: Thu Sep 16, 2010 11:08 pm Post subject: |
I think they've made a mistake. It should be 65 Watt.
daleakins
Posted: Thu Sep 16, 2010 11:12 pm Post subject: |
I do not know if the ADO5000DSWOF will work or not. I contacted HP and i told them i could not find a "64 watt" CPU and they gave me this link. I was blown away when the price tag slapped me side my head! For some reason this site has the one HP told me to get rated at 65 watt. HP said it was 64 watt. They said the cpu that i use to upgrade HAD to be 64 WATT ONLY. What do you think? LOL.
Here is the specs they gave me to use to upgrade:
Socket: AM2
Supports the following processors:
Athlon 64
Sempron
With this info which cpu should i get. I do not need nothing fancy. just dual core. The one i have now is a 1.8 single core. |
Posted: Fri Sep 17, 2010 9:29 am Post subject: |
I tried to find what other people upgraded this system to, and I couldn't find anything. So, like I said before, ADO5200IAA6CS, ADO5000IAA5CS or ADO5000IAA5CU have the best chance to be supported by your motherboard. Performance difference between 5200+ and 5000+ is negligible, so you can get any one. ADO***DO or ADO***DS have slightly lower chance to be supported, but you can get faster processor.
