Unlocking 4th Core on Athlon II X3 440
Alex
PostPosted: Fri Oct 22, 2010 12:49 pm    Post subject: Unlocking 4th Core on Athlon II X3 440 Reply with quote
I have an Athlon II x3 440 with a Motherboard Asrock n68-s ucc. I can unlock the 4th core, see the changes in the BIOS, but then it doesn't start windows 7.
If the 4th core is defective it shouldn't appear in the BIOS. or it doesn't matter.
What can I do?
need some help. Thank you.
PostPosted: Fri Oct 22, 2010 1:30 pm    Post subject: Reply with quote
1. Try to raise core voltage a little.
2. Play with ACC settings. On one of my processors I had to change ACC from 'Auto' to '-2' or something similar to make it work.
viili
PostPosted: Fri Oct 22, 2010 3:39 pm    Post subject: Reply with quote
Sometimes one (or more) of the cores are disabled for a reason, not to rip you off. You bought a processor with 3 good cores, and got just that.
