Bernie the Bolt
Posted: Wed Mar 23, 2011 2:48 pm Post subject: Socket LGA775 query |
My Foxconn mobo supports socket LGA 775 cpu's. I am looking to buy a used Intel core 2 duo E6750 which is socket [u]P[/u]LGA 775. Will this be compatible with my mobo. What does the P stand for?
Also, the E6750's spec includes "Instruction set - 64 bit" Does that mean it is not compatible with my XP 32 bit OS or does it mean that it supports [u]up[/u] to 64 bit.
I would appreciate answers to both queries if that's ok |
Bernie the Bolt
Posted: Wed Mar 23, 2011 2:53 pm Post subject: |
| I have just submitted this query and I notice the letter P and the word up which I should have been underlined, has been has not been converted correctly. The E6750 socket should therefore read PLGA 775 and the second paragraph should read- up to 64 bit |
Posted: Wed Mar 23, 2011 4:32 pm Post subject: Re: Socket LGA775 query |
| Bernie the Bolt wrote: | | My Foxconn mobo supports socket LGA 775 cpu's. I am looking to buy a used Intel core 2 duo E6750 which is socket PLGA 775. Will this be compatible with my mobo. What does the P stand for? |
It's not possible to tell that without knowing you motherboard model. It will fit into socket, but there are other things that may affect compatibility (chipset, BIOS, etc).
| Quote: | Also, the E6750's spec includes "Instruction set - 64 bit" Does that mean it is not compatible with my XP 32 bit OS or does it mean that it supports up to 64 bit.
All 64-bit x86 processors, including E6750, are backwards compatible with 32-bit software.
Bernie the Bolt
Posted: Thu Mar 24, 2011 9:58 am Post subject: |
Many thanks for your reply GHSV.
My Foxconn series number is :- M7VMX and the Manual shows it supports Core 2 Quad, Core 2 Extreme and Core 2 duo together with 1333/1066/800 Mhz FSB. I assume therefore the E6750 socket PLGA 775 cpu will also be compatible with the BIOS. As a matter of interest, what does the P stand for?
Given the above information, I would appreciate you confirmation the E6750 will be OK.  |
vezhlys
Joined: 01 Jun 2008 Posts: 411 Location: Lithuania, Vilnius
koer
Joined: 24 Dec 2010 Posts: 21 Location: Tallinn, Estonia
Bernie the Bolt
Posted: Thu Mar 24, 2011 3:59 pm Post subject: |
| Many thanks both of you. |
