Question on ES datecode
PostPosted: Fri Sep 30, 2011 10:31 pm    Post subject: Question on ES datecode Reply with quote
Hi I recently come across a few ES were made right after the production date. They looks fine but I cannot explain the datecode issue.
I did not buy them so I prefer not to post pictures.
I just ask questions:
Do you believe a Intel A80386DX-20 ES was made at 1991? While there are mass product of DX-20 at 1989. And Even a lot kinds of A80486 production were made between 1989~1991.
Another is AMD 486DX4100-V16BGC ES, its datecode is also far behind some normal productions of the same kind, which I mean same suffix and same stepping. Confused
My vintage CPU collection:www.cpumuseum.com
Chinese Forum: http://www.cpumuseum.com/forum
PostPosted: Fri Sep 30, 2011 11:03 pm    Post subject: Reply with quote
Intel 386DX-20 was made until 2007 and I have seen personally seen examples of 2002 production
just not sure when the final stepping first came out
PostPosted: Fri Sep 30, 2011 11:09 pm    Post subject: Reply with quote
Do you know how many stepping for 386?
PostPosted: Fri Sep 30, 2011 11:14 pm    Post subject: Reply with quote
well there is 4 known listed in CPU-World info pages
but an ES could also be for other reasons like a die shrink
can you post a picture of the bottom at least and see if die cap matches time period
PostPosted: Fri Sep 30, 2011 11:32 pm    Post subject: Reply with quote
the marking on top:
A80386DX-20 IV
Q328
L1335671
i M C 1985 1987
the marking on bottom:
91079191NE
MALAY
131
DB
PostPosted: Fri Sep 30, 2011 11:38 pm    Post subject: Reply with quote
markings look all good
this really looks like a qualification rather than a Engineering sample
found references to these.. so I would go for it
A80386DX-16 Q327
A80386DX-20 Q328
A80386DX-25 Q329
PostPosted: Fri Sep 30, 2011 11:49 pm    Post subject: Reply with quote
I agree. It looks like qualification sample.
PostPosted: Fri Sep 30, 2011 11:58 pm    Post subject: Reply with quote
then it was made to qualify with what issue at such a later date?
PostPosted: Sat Oct 01, 2011 12:18 am    Post subject: Reply with quote
could be just a minor stepping change
