CPU-World information - Part 3
Goto page 1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Thu Apr 12, 2012 3:04 am    Post subject: CPU-World information - Part 3 Reply with quote
I dont like really long threads.. makes it hard searching.. so split it up and started a 3rd one
I noticed an error regarding CPUid on the PODP5V63 page
presently is
CPUID 1531 (SU013, SZ953, SZ990)
should be
1531 (SZ953, SZ990)
1532 (SU013)
PostPosted: Fri Apr 13, 2012 4:09 pm    Post subject: Reply with quote
The error was on the SU013 s-spec page, and incorrect CPUID came from Intel spec update. I fixed it (I mean the S-spec page, not the s-spec update Smile). Thank you!
PostPosted: Mon Apr 30, 2012 11:38 pm    Post subject: Reply with quote
will be last thing on your list.. but new scripts for sSpecs may change the outcome anyway
duplicate sSpecs are dealt with in forum, but if you use the bulk sSpec page seems to default to listing the non CPU part first (but it may just default to first part in database)
but if you click on sSpec takes you to the CPU part page
an example of a sSpec used for CPU & non CPU
Q810 ( 82801AB)
Q811 ( 82801AB)
way way down the track.. wonder if another colour could be used to highlight sSpecs that are in database more than once when using bulk sSpec page
PostPosted: Wed May 02, 2012 9:12 pm    Post subject: Reply with quote
It has passed my mind a few times, but now with new CPU submission page think it might be pertinent
I think most submission pages (also maybe comments) start with oldest at top.. if only a few submissions not a issue
but if there is a lot wouldn't it best (if it can) have the newest first going to oldest?
PostPosted: Thu May 17, 2012 10:43 pm    Post subject: Reply with quote
another you might want to put on your list.. for when you have nothing to do Laughing
You have listed for Ezra & Samuel 2 C3s
Floating Point Unit >> Integrated, running at 1/2 speed
but for Samuel C3s you have
even though they also only run at 1/2 speed also
PostPosted: Tue May 22, 2012 5:44 pm    Post subject: Reply with quote
I added it to my list of things to do.
PostPosted: Thu Jun 14, 2012 11:04 pm    Post subject: Reply with quote
small typo
Higher power dissipation will also shorten batter life in the notebook.
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%2064%20TF-20%20-%20AMGTF20HAX4DN.html
PostPosted: Thu Jun 14, 2012 11:40 pm    Post subject: Reply with quote
Neon_WA wrote:
small typo
Fixed. Thank you!
Robev
PostPosted: Fri Jun 15, 2012 12:26 am    Post subject: Reply with quote
gshv wrote:
Neon_WA wrote:
small typo
Fixed. Thank you!
Still shows as "batter" instead of "battery"
PostPosted: Fri Jun 15, 2012 12:27 am    Post subject: Reply with quote
Try to refresh the page (Ctrl-R in Firefox and probably other browsers).
picur10
PostPosted: Thu Jul 12, 2012 8:21 am    Post subject: Reply with quote
Celeron 460 is missing from this page.
Many Sun families missing from the drop down list on the main page.
PostPosted: Thu Jul 12, 2012 8:34 am    Post subject: Reply with quote
check listings on the "Samples Only" tab Wink
picur10
PostPosted: Thu Jul 12, 2012 8:42 am    Post subject: Reply with quote
ouch Embarassed Very Happy
PostPosted: Mon Aug 20, 2012 1:06 pm    Post subject: Reply with quote
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%2064%203200+%20-%20ADA3200AIO4BX%20%28ADA3200BXBOX%29.html
Typo: TDP 59W, shouldn't be 89?
I see other 59W for 754... big series of typos or I missed something that i'm about to learn.
PostPosted: Mon Aug 20, 2012 3:37 pm    Post subject: Reply with quote
ADAxxxxAEPxxx had 1.5 core voltage. ADAxxxxAIKxxx had lower 1.4 V voltage, and lower TDP. I don't remember which source I used, but it probably came from older revisions of "AMD Athlon 64 Processor Power and Thermal Data Sheet". You can find the latest version of it on AMD website. It still has data for ADA3000AIK4BX CPU, which is rated at 51 Watt TDP.
Page 1 of 8
