Tegranphos
Joined: 04 Oct 2009 Posts: 806 Location: Navarra - Spain
Posted: Wed May 30, 2012 12:54 pm Post subject: missing pin in Celeron 1000A SL5VP |
Hello, I recently found 2 Celeron 1000A SL5VP but the two chips have the same pin missing (first in one corner) and my question is: Is it normal or I have bad lucky?
Sorry but no photo, my camera said good bye when i try take the photo :_( |
mavroxur
Posted: Wed May 30, 2012 3:52 pm Post subject: |
| Socket 370 has one "missing" pin in two corners. Is this what you're talking about? |
Tegranphos
Posted: Wed May 30, 2012 7:07 pm Post subject: |
mmm... ovbiously... not.
Te CPU with the two corners with the oficialy missing pins in down, and in the left inferior corner, first pin and two more that not seeing after. _________________ My small x86 collection: http://tegranphos.x86-guide.com/en/collection.html |
Tegranphos
Posted: Wed May 30, 2012 7:33 pm Post subject: |
| Photo-shop with red marked missing pins in the two procesors. |
Tegranphos
Posted: Wed May 30, 2012 7:52 pm Post subject: |
what i was thinking seeing what the pins were for
from left to right
Pin A3 > AGTL I/O
Pin E3 > AGTL I/O
Pin D4 > AGTL I/O _________________ There are 10 types of people in this world:
Tegranphos
Posted: Thu May 31, 2012 9:30 am Post subject: |
wow sorry, two days without sleep and anybody will forgot that pins are inverted xD
New photo: when i put the chip in it, the red pins are the pins that are missing. I hope that this time is OK xD |
Posted: Thu May 31, 2012 6:17 pm Post subject: |
pins from top to bottom
AN3 > DYN_OE
AK4 > VttPWRGD
AJ3 > RESET2#
The DYN_OE allows the BSEL and VID signals to be driven out from the processor.
When this signal is low (a condition that will occur if the Intel® Pentium® III
processor is installed in a non-supported platform), the VID and BSEL signals will
be tri-stated and the platform pull-up resistors will set the VID and BSEL to all ‘1’s’
which is a safe setting.
The VTT_PWRGD signal informs the system that the VID/BSEL signals are in their
correct logic state. During Power-up, the VID signals will be in a indeterminate state
for a small period of time. The voltage regulator or the VRM should not sample and/
or latch the VID signals until the VTT_PWRGD signal is asserted. The assertion of
the VTT_PWRGD signal indicates the VID signals are stable and are driven to the
final state by the processor.
RESET2# pin is provided to differentiate the Intel® Pentium® III processor with
512KB L2 Cache from legacy Pentium® III processors. The Intel® Pentium® III
processor with 512KB L2 Cache. does not use the RESET2# pin. _________________ There are 10 types of people in this world:
