Identification help request
JardaXor
PostPosted: Mon Sep 17, 2012 8:55 am    Post subject: Identification help request Reply with quote
I found these nice chips, but can't find what are exactly.
Can anybody help?
PostPosted: Mon Sep 17, 2012 9:06 am    Post subject: Reply with quote
the AMI are custom chips.. part number starts with C
the HPs are most likely custom masked ROMs
JardaXor
PostPosted: Tue Sep 18, 2012 4:47 am    Post subject: Reply with quote
Thanks, i supposed something like this...
But I have new question Smile
PostPosted: Tue Sep 18, 2012 5:37 am    Post subject: Reply with quote
These Fairchilds are most likely Gate Arrays
The Fanuc marked ones are for a CNC machine
Robev
PostPosted: Tue Sep 18, 2012 6:02 am    Post subject: Reply with quote
Try Fujitsu Wink
PostPosted: Tue Sep 18, 2012 6:27 am    Post subject: Reply with quote
Robev wrote:
Try Fujitsu Wink
yep.. been a long day today Rolling Eyes
JardaXor
PostPosted: Tue Sep 18, 2012 6:49 am    Post subject: Reply with quote
Thanks Smile
JardaXor
PostPosted: Sat Sep 22, 2012 7:35 am    Post subject: Reply with quote
Another secret chip... Smile
PostPosted: Sat Sep 22, 2012 9:11 am    Post subject: Reply with quote
VIA Samuel2 C3 wafer test sample
CPUid will be 6.7.2
http://www.cpu-world.com/forum/viewtopic.php?t=18645
JardaXor
PostPosted: Sat Sep 22, 2012 1:59 pm    Post subject: Reply with quote
Wow... where are informations like this one? About sign of test samples etc?
PostPosted: Sat Sep 22, 2012 7:54 pm    Post subject: Reply with quote
on this particular chip they have used internal die code name C5B
C5B denotes Samuel2 core
0E denotes 5th core revision
I still need to work if they skipped any letters used in core revision
Looking all my C3s in my database it appears they didnt use the ES marking unless the chip was likely to released to a OEM
this also why there are no print marking on the heat-spreader cap
for reference even thou it is not dated.. will be likely from around week 30 2001
JardaXor
PostPosted: Sun Sep 23, 2012 10:42 am    Post subject: Reply with quote
Interesting. I found some lists of VIA ES, have to study... Smile
I'll look for proper board and try to run this one.
There are next picture for identification help...
berni
PostPosted: Sun Sep 23, 2012 2:07 pm    Post subject: Reply with quote
The IMSG170 are color look-up tables for graphic display systems...
berni
Robev
PostPosted: Sun Sep 23, 2012 2:10 pm    Post subject: Reply with quote
berni
Thanks for that Berni as I also have some of each type of these Proms as well. Very Happy
Would love to know what the NCR Marked ones are if anyone knows
JardaXor
PostPosted: Sun Sep 23, 2012 2:20 pm    Post subject: Reply with quote
Fine, thanx ... is it PROM derrived from EPROM or masked? Does anyone know?
