Socket F question
PostPosted: Thu Jan 31, 2013 6:41 pm    Post subject: Socket F question Reply with quote
Are chips that the database describes as being Socket Fr6(1207) compatible with motherboards that are only described as Socket F (1207)? I'm wondering whether I will need a second 4-way board to test the chips I just bought from John, or if there is a chance they will work in the HP board I just bought with quad 8218.
If I will need another board, what do I need to look for in seller descriptions?
PostPosted: Thu Jan 31, 2013 7:12 pm    Post subject: Reply with quote
It depends on the board. Some socket F boards do support Second Generation, Third Generation (Quad-Core) and Six-Core Opterons. What is the board name and/or chipset on the board?
PostPosted: Thu Jan 31, 2013 7:32 pm    Post subject: Reply with quote
It's a board from a Dell Poweredge 6950. So far I have established that it can take 3rd gen Opterons, but 6-core Opterons I'm not sure about.
PostPosted: Thu Jan 31, 2013 10:15 pm    Post subject: Reply with quote
It looks like it works with Barcelona quad-core Opterons, but doesn't support Shanghai Opterons. Six-core Opterons are not supported either.
PostPosted: Thu Jan 31, 2013 10:30 pm    Post subject: Reply with quote
Oh well, looks like that means one more board to keep on my shopping list. I have a habit buying wrong boards! I think better research is in order for my next purchase Smile
