Any idea what this is? AMD Athlon II AEV62LHFK23GQ
Tarmack
PostPosted: Mon Jan 06, 2014 5:51 am    Post subject: Any idea what this is? AMD Athlon II AEV62LHFK23GQ Reply with quote
Any idea what this is? Cannot find it on the web.
AMD Athlon II
AEV62LHFK23GQ
AAEEC AE 0921CPAW
PostPosted: Mon Jan 06, 2014 8:20 am    Post subject: Reply with quote
It is an embedded class processor.
Athlon II XLT V62L
K10 microarchitecture "Regor" core
socket AM3
45 W
2 cores, 1MB L2 cache per core
I don't know the max frequency, probably 2.5 or 2.6 GHz
Tarmack
PostPosted: Mon Jan 06, 2014 7:10 pm    Post subject: Thank you Neon! Reply with quote
Thank you Neon! That makes sense considering where I got it - they must have been doing evaluations on it.
It fits into a Socket AM3 MoBo so I was going to try it - I think it should work as the frequency and voltage info are supplied by the CPU itself - correct?
It probably won't show up correctly in Windows as the BIOS won't be updated for that processor's ID, but it should run like any other Regor core CPU - correct?
PostPosted: Mon Jan 06, 2014 7:30 pm    Post subject: Reply with quote
I think your assumptions are correct.
It should function, and it might not be identified correctly. Please let us know what you find.
