Remove cement on IBM cpu
PostPosted: Fri May 23, 2014 2:42 pm    Post subject: Remove cement on IBM cpu Reply with quote
I'm not able to remove "cement" on Power4 and Power5 CPUs
I read about tuolene or Brake Cleaner with Xilene (not commercialized in Italy but I can buy xilene alone)
so which is the best formula, 50/50 acetone/xilene?
acetone/xilene/alchol?
and which is the best way to remove this damn "cement"?
a bath for some days?
or rub it for some hours?
thanks for any suggestion
aberco
PostPosted: Fri May 23, 2014 3:12 pm    Post subject: Reply with quote
I have been able to remove some of it heating the die a bit with a gas torch, then you can scrape it off with a soft tool (I used a screwdriver wrapped in a paper towel) when it's hot.
These are not thermally coupled by the grey paste commonly used on Power CPUs, and likely can't be chemically dissolved.
It works well to remove it all on the die, however it's hard to remove it on the black epoxy sealant.
Check results here:
If anyone has a better idea I'd also be happy to know.
Vlasta
PostPosted: Sat May 24, 2014 6:09 am    Post subject: Reply with quote
Use paint stripper (the jelly type) and a toothbrush.
best rgds.
Steve
PostPosted: Sat May 24, 2014 7:02 am    Post subject: Reply with quote
Do you have an example of a product name or what the active ingredient is? Just thinking there may be similar looking products that don't work, and other products with the same chemicals that do work.
Vlasta
PostPosted: Sat May 24, 2014 12:30 pm    Post subject: Reply with quote
http://www.cpu-world.com/forum/viewtopic.php?t=23248
best rgds.
Steve
PostPosted: Sat May 24, 2014 1:16 pm    Post subject: Reply with quote
Cool, forgot you had already posted the name for those who need it Smile
PostPosted: Sat May 24, 2014 2:12 pm    Post subject: Reply with quote
"cement" on IBM chips seem to be a sort of resin not an indelible paint or do you tried it also on this resin with good results?
aberco
PostPosted: Sun May 25, 2014 2:10 pm    Post subject: Reply with quote
It has to be a Power4, Power4+ or Power5.
These came with the ceramic heatspreader and were glued using this very hard, white cement.
I'd be interested as well if it work specifically on this and the application procedure.
Vlasta
PostPosted: Sun May 25, 2014 7:13 pm    Post subject: Reply with quote
Aha - the resin is probably an epoxy glue. Not sure how to remove this. I was thinking more of the grease/gunk stuff under the heat sink. Silicone glue can also be removed with a product called silicone-be-gone - google it......
best rgds.
Steve
aberco
PostPosted: Sun May 25, 2014 7:17 pm    Post subject: Reply with quote
Yeah this is not silicon grease.
It really look like some sort of cement. It is very hard, but get less resistant when heated. It also does not look like an epoxy resin (the black underfill is however an epoxy).
PostPosted: Fri Aug 15, 2014 4:46 pm    Post subject: Reply with quote
I've come across another product that has removed cement on all chips I've used it on. Here in the UK it's sold as Cellulose Thinners, and it is a mix of Methyl Ethyl Ketone and Methyl Isobutyl Ketone.
I apply it to a cloth and wipe the cement. This softens the surface of the cement allowing me to then scrape some of it away. i usually have to redo this a few times. I have cleaned the cement used on Pentiums as well as other early chips, and GPUs. It can take 20-30 minutes, but the chips are always as new when I am finished.
I have almost finished a 125 ml bottle and just bought 500 ml. It's pretty cheap here.
Vlasta
PostPosted: Fri Aug 15, 2014 6:49 pm    Post subject: Reply with quote
Got any before and after photos?
best rgds.
Steve
PostPosted: Fri Aug 15, 2014 6:50 pm    Post subject: Reply with quote
No, but I'll remember to take pics next time I clean a chip.
