Vlasta
Posted: Sun Apr 27, 2014 9:36 pm Post subject: Cleaning Your Wafers |
Hi - I get a lot of wafers through my hands and some are dirty through age or handling and some are marked with the red or black dots of death - i.e. the dies are marked as defective in the fab.
So - dirty discs:-
1. Warm soapy water - beware - these suckers are slippery when wet
2. Clean gently
3. Rinse carefully
4. Buff with a soft lint free cloth
Dots of death
After trying acetone, xylene, perc, bleach, meths, white spirit, turps..... I finally came across something that works - "Polystrippa" - a dichlormethane based gel paint stripper.
1. Put some "polystrippa" on a cotton bud
2. Rub off the dots of death
3. Rinse in warm soapy water
Voila - clean discs. _________________ best rgds.
Steve |
aberco
Joined: 05 Sep 2013 Posts: 2655 Location: Paris France
Posted: Mon Apr 28, 2014 5:47 am Post subject: |
Cool tip, I have been lucky to remove the dot on most dies with acetone, but I have some that just won't go away.
Will try that tip and look for that product! |
Vlasta
Posted: Mon Apr 28, 2014 5:55 am Post subject: |
Here it is! _________________ best rgds.
Steve |
Vlasta
Posted: Tue Apr 29, 2014 7:21 am Post subject: |
Before and After _________________ best rgds.
Steve |
aberco
Posted: Wed Jun 04, 2014 3:02 pm Post subject: |
So far acetone has worked on most dies I had, I went go shopping for paint remover that look like polystrippa.
I got something that's a transparent gel, but no brand would write the detailed chemical composition (so I don't know if they are dichloromethane based).
I was out of luck to remove the dot on my TI MicroSPARC dies, it look very waxy. |
