..and i did it :(((
cedrik
PostPosted: Mon Nov 03, 2014 3:47 pm    Post subject: ..and i did it :((( Reply with quote
trying to remove a heatsink, i broke a chip.. first in 5 years... do you have any ideea what this coould be?
thanx
https://www.facebook.com/CPUCollectionRO
View user's profile Send private message [ Hidden ] Yahoo Messenger
aberco
PostPosted: Mon Nov 03, 2014 3:52 pm    Post subject: Reply with quote
Not a CPU, having a large view of the board and an idea of where it came from can help.
Better heating heatsinks with heatgun before starting prying them off.
cedrik
PostPosted: Mon Nov 03, 2014 4:24 pm    Post subject: Reply with quote
the board
cedrik
PostPosted: Mon Nov 03, 2014 5:15 pm    Post subject: Reply with quote
watching with a small microscope, in a corner i saw an 108L, 188L , 100L or 168L code.... if this helps
aberco
PostPosted: Mon Nov 03, 2014 5:28 pm    Post subject: Reply with quote
A bit hard to say without all the part numbers etc...
It might be a CPU but the die doesn't look like it, could be custom logic.
You could lend the die to Birdman for a nice photo
cedrik
PostPosted: Mon Nov 03, 2014 6:01 pm    Post subject: Reply with quote
i'll try to make a photo, and if i coulndt do it i'll send it to Birdman...
thanx
PostPosted: Mon Nov 03, 2014 6:10 pm    Post subject: Reply with quote
wow big heat spreader for this chip...
Also the white stickers on pcb may help us with part Number of pcb..
i have find some years ago a similar pcb with smaller heat spread and was ram controller after enough Research
Also imo not looks like custom logic or gate array ....
worth a research
cedrik
PostPosted: Mon Nov 03, 2014 6:32 pm    Post subject: Reply with quote
labels
cedrik
PostPosted: Mon Nov 03, 2014 6:36 pm    Post subject: Reply with quote
looks like its a "CIO channel adapter board - Activates upper HP-PB slot for CIO - Used with CIO/HP-PB connector adapter board & a CIO I/O " but no clue on the chip
