CPU-World Information: Edits, Errors, Updates etc
PostPosted: Tue Feb 16, 2016 9:22 pm    Post subject: CPU-World Information: Edits, Errors, Updates etc Reply with quote
Stu had several of these threads to help correct errors in the CPU-World.com database, so I am starting another
First up
http://www.cpu-world.com/cgi-bin/IdentifyPart.pl?PART=ZS202045TCG43&PROCESS=Go
Shows L3 cache as either 16M or 12M
The actual part number page shows 12M or 24M
http://www.cpu-world.com/CPUs/Bulldozer/AMD-Opteron%20ZS202045TCG43.html
I think 16M is right
PostPosted: Wed Feb 17, 2016 1:20 am    Post subject: Reply with quote
The answer is both, depending on which way you want to look at it. Wink I will try to explain:
The 6-core Opteron ("Istanbul"), Opteron 6100 series ("Magny-Cours"), 6200 series ("Interlagos"), and 6300 series ("Abu Dhabi") use a Probe Filter that AMD calls "HT-Assist". The purpose of a probe filter is to help maintain cache coherency across all of the processor cores.
Quote:
HT Assist, or the Probe Filter as it is sometimes called, works by using part of the processor’s L3 cache as a directory cache. This directory cache tracks all cache lines cached in the system. Instead of generating numerous cache probes when checking a cache line the processor does a Probe Filter Lookup. This helps lower latency for accesses to local DRAM because there is no need to wait for probe responses when accessing local data. This also means there is less queuing delay due to the lower HyperTransport technology traffic. With significantly reduced probe traffic it effectively also increases system bandwidth performance. It also should be noted that the directory cache uses 1MB of the 6MB L3 cache in the case of the Six-Core AMD Opteron processor.
http://developer.amd.com/community/blog/2009/07/21/ht-assist-what-is-it/
So, part of the L3 cache gets used as a directory cache for the probe filter, and it is unavailable to the OS. The OS does not see that portion of the L3 cache.
On Istanbul, the probe filter is enabled only for 4-socket or 8-socket implementations. On Magny-Cours, Interlagos, and Abu Dhabi the probe filter is apparently enabled by default, because those are all 2 node processors (MCM).
Istanbul: 6MB physical L3 | 5MB OS-useable L3 (in 4-socket or 8-socket systems only)
Magny-Cours: 12MB physical L3 | 10MB OS-useable L3
Interlagos: 16MB physical L3 | 12MB OS-useable L3
Abu Dhabi: 16MB physical L3 | 12MB OS-useable L3
So there is the source of confusion. AMD literature shows the Interlagos CPUs have 16MB L3. They do, but the OS only sees 12MB L3 because 4MB is used for the probe filter.
Additional references:
1. https://tu-dresden.de/die_tu_dresden/zentrale_einrichtungen/zih/forschung/projekte/benchit/2014_MSPC_authors_version.pdf
section 3.2
2. http://www.hotchips.org/wp-content/uploads/hc_archives/hc23/HC23.19.9-Desktop-CPUs/HC23.19.940-Bulldozer-White-AMD.pdf
p. 17
3. http://www.cs.columbia.edu/~junfeng/12sp-w4118/lectures/amd.pdf
p. 11
PostPosted: Wed Feb 17, 2016 2:11 am    Post subject: Reply with quote
Excellent, and makes perfect sense too
Though not sure where 24MB came from haha
PostPosted: Sun May 15, 2016 1:14 am    Post subject: Reply with quote
http://www.cpu-world.com/sspec/QG/QGYA_1.html
Wrong core info here
rjluna2
PostPosted: Mon Jul 18, 2016 6:14 pm    Post subject: Reply with quote
I was uploading some pictures for the site and all of sudden I get this ad only with nothing below. I am running Internet Explorer 10 32-bit.
Elar
PostPosted: Sun Jul 24, 2016 12:09 pm    Post subject: Reply with quote
Same with IE11. Putting cpu-world.com to Compatibility View settings fixes this.
rjluna2
PostPosted: Sun Jul 24, 2016 12:40 pm    Post subject: Reply with quote
Thanks, Elar Smile
Also, pressing the Esc key stop the process as well after loading the page. Sometimes it is a hit or miss as well.
PostPosted: Wed Jul 27, 2016 5:28 pm    Post subject: Reply with quote
I believe this is fixed now. Please see if it works for you.
rjluna2
PostPosted: Thu Jul 28, 2016 6:21 am    Post subject: Reply with quote
I will try that at the next time I use the computer that has IE10 32-bit. I'll let you know by then. Thanks, Gennadiy Wink
rjluna2
PostPosted: Fri Jul 29, 2016 6:31 pm    Post subject: Reply with quote
That fixed the problem. Thanks, Gennadiy Smile
PostPosted: Thu Sep 08, 2016 8:18 am    Post subject: Reply with quote
I'm getting the same problem in the latest version of Firefox on Windows 10 64-bit. The page appears to load the once the advert has loaded the page disappears. Sometimes get the ad plus the message to disable my ad blocker.
PostPosted: Sat Sep 10, 2016 4:32 am    Post subject: Reply with quote
Same here. I just tried to completely disable all my adblocks plugins (even if cpu-world was whitelisted) and I still can't access the site with Firefox. Always get the message :-/
rjluna2
PostPosted: Mon Nov 14, 2016 7:39 am    Post subject: Reply with quote
When I visited this site: http://www.cpu-world.com/news_2016/2016111201_Pre-order_prices_of_Core_Celeron_and_Pentium_Kaby_Lake_CPUs.html it came up blank. I am using Internet Explorer 9 64-bit.
Could the CPU-World page only support Internet Explorer 10 or later? Confused
PostPosted: Tue Nov 15, 2016 4:38 pm    Post subject: Reply with quote
It should support IE 9 and earlier. I just checked that page in IE 8 and I also see a blank page. I'll try to fix it tonight...
PostPosted: Tue Nov 15, 2016 11:42 pm    Post subject: Reply with quote
It was fixed. Thanks for reporting it!
