Matsonic MS7112c with 933 Mhz P3??
pikomil
PostPosted: Sun Jan 15, 2006 12:39 pm    Post subject: Matsonic MS7112c with 933 Mhz P3?? Reply with quote
Could somebody give me information if Pentium III 933 Mhz (FCPGA) processor would work normaly on Matsonic MS7112c mainboard?
I've been already checking in mainboard manual, where it says that supporst PIII processors up to 850 Mhz. Curently i'm running on that board Celeron 700 Mhz. Oh, both are Socket 370 processors.
Thanks for all information and answers.
PostPosted: Sun Jan 15, 2006 1:00 pm    Post subject: Reply with quote
Some years ago I had this mobo Smile Really bad - not stabile mobo. I think this mobo will not work with PIII 933. It doesn't support FSB 133. PIII 850 is supported on 100 MHz bus and I think 8.5 is max multiplier.
bacterio
PostPosted: Sun Jan 15, 2006 1:07 pm    Post subject: Reply with quote
Update the BIOS and try it. Maybe it will go or not Wink
pikomil
PostPosted: Sun Jan 15, 2006 1:12 pm    Post subject: Reply with quote
Thank you very much. I saw a good offer for P 3 processor, but as I said I wasn't sure if this combination would work.
skold
PostPosted: Sun Jan 15, 2006 6:02 pm    Post subject: Reply with quote
even if the board says it doesnt support a particular speed grade, it'll most likely work as long as it supports that processor.. ie, if it supports any fcpga P3s, they should all work..
pikomil
PostPosted: Mon Jan 16, 2006 3:19 am    Post subject: Reply with quote
Well, I'am of same thoughts about this combination, but it ist understood, that I would not like to waste money on something, that in the end I could not use. Thank you skold.
