Katmai500
Joined: 30 Sep 2010 Posts: 360 Location: Southern NJ, USA
Posted: Tue Jul 23, 2019 6:21 pm Post subject: Unusual Intel Slot(?) Sample |
I just got this really strange intel sample. Some of you may have already seen this one.
It looks like it could be a Test Vehicle from the TV "D" marking. I don't have a clue on DCARD. It is the same physical size as a Slot 1 PCB, and has similar heatsink mounting hole positions, but no notches at the top corners. The connector at the bottom is only single-row instead of double, but has a narrower notch in the same spot as SC 242. The manufacturing date appears to be Week 32, 1996. So it's early enough to be pre-retail Slot 1, but made the same week as known early Pentium II samples like Q999.
The Toshiba cache chips are ES and the intel chip on the back is marked DC SAMPLE. Unfortunately the BGA package has been de-soldered and is missing. That might have given a better clue as to what this is.
The reference CPU is a Pentium II 350 SL356 (Week 9, 1999).
Katmai500
Posted: Tue Jul 23, 2019 6:34 pm Post subject: |
| The position of C55 is very similar to C92 on the SECC Klamath PCB. That PCB might be a better comparison since it's closer in age to this sample than the SECC 2 version. |
karman
Posted: Wed Jul 24, 2019 5:25 am Post subject: |
| The connector reminds me of ISA cards. |
oldirdey
Posted: Wed Sep 25, 2019 8:22 am Post subject: |
Here I have a tray with unknown Samples, maybe they fit together?!
cuttingedgecs
Posted: Wed Sep 25, 2019 9:25 am Post subject: |
| I notice on the right side of the board when the Toshiba chips are facing you, there is what looks like a printed antenna. This could have been some sort of attempt at a wireless display video card or display extender with the chips being a buffer or video memory rather than cache? |
Posted: Wed Sep 25, 2019 9:55 am Post subject: |
| cuttingedgecs wrote: | | I notice on the right side of the board when the Toshiba chips are facing you, there is what looks like a printed antenna. This could have been some sort of attempt at a wireless display video card or display extender with the chips being a buffer or video memory rather than cache? |
This looks like a trimmed shunt (low value resistor to measure current) _________________ ES-Only Collector : http://www.engineering-sample.com
Universal Chip Analyzer (UCA) : https://x86.fr/uca / http://www.cpu-world.com/forum/viewtopic.php?t=34349 |
H3nrik V!
Posted: Thu Sep 26, 2019 1:50 am Post subject: |
| xsecret wrote: | | cuttingedgecs wrote: | | I notice on the right side of the board when the Toshiba chips are facing you, there is what looks like a printed antenna. This could have been some sort of attempt at a wireless display video card or display extender with the chips being a buffer or video memory rather than cache? |
This looks like a trimmed shunt (low value resistor to measure current) |
The "interleaved fork" like pattern, makes me think more of a moisture sensor? |
