Posted: Sat Jan 04, 2020 3:55 pm Post subject: Re: X89 |
Thanks for sharing us those infos. Propably I will order a nice one for Socket G34 Opterons. You had to use RECC memory or it works with standard desktop DDR3 ? Have you tested those ES from crazybubba64 ? |
Posted: Sat Jan 04, 2020 4:07 pm Post subject: Re: X89 |
| Marcin wrote: |
I used regular DDR3. The only Opteron I managed to run so far with my power supply is a 6128. I also tested a 6238, and my power supply is crashing during Windows 10 install, after reaching 315-320W of full system consumption (on the plug). The 6128 stays below 270W.
I also tested a 6212, but it won't boot...
Tomorow I will try with the ZS200800TCE25 I got from Crazybubba but I don't think my power supply will like it... _________________ Register on x86-guide.net to manage and share your collection on-line !
Need to find a x86 ? Go to http://www.x86-guide.net ! Over 12000 chips listed ! |
Posted: Sat Jan 04, 2020 4:14 pm Post subject: Re: X89 |
| Mixeur wrote: | The only Opteron I managed to run so far with my power supply is a 6128. I also tested a 6238, and my power supply is crashing during Windows 10 install, after reaching 315-320W of full system consumption (on the plug). The 6128 stays below 270W.
Tomorow I will try with the ZS200800TCE25 I got from Crazybubba but I don't think my power supply will like it... |
From CPU World database info Opteron 6238 have :
Average CPU Power 80 Watt
Thermal Design Power 115 Watt
Are you using power hungry VGA with that configuration or CPU takes much more than is stated in database ? What king of PSU you use ? |
Posted: Sat Jan 04, 2020 5:00 pm Post subject: |
I'm using an ATI Radeon 5870. Not so hungry I think, but the powermeter can't lie.
I'm using an old 480W PSU from the P4 era. I think that 12V line is really too weak.
With the 6238, Windows 10 won't install. But now it is installed using the 6128, I will try again tomorow with the 6238 and the other ones I have. _________________ Register on x86-guide.net to manage and share your collection on-line !
crazybubba64
Posted: Sat Jan 04, 2020 6:19 pm Post subject: |
I wish I knew about the G34 board back when I was testing those CPUs. I had a whole HP Proliant DL385 I had to lug around to POST test all of them.
Might pick up a few of these. _________________ My collection |
Posted: Sat Jan 04, 2020 6:35 pm Post subject: |
| Mixeur wrote: | | I'm using an ATI Radeon 5870. Not so hungry I think, but the powermeter can't lie. |
Reference spec for the HD 5870 is 188 W, so not exceptionally high. _________________ My graphics card database can be found at http://www.gpuzoo.com.
