sebskyman
Posted: Wed Sep 16, 2020 11:00 am Post subject: Processors with Black caps |
Hi guys,
I have just got a CPU with a black capsule on it. for me it looks like an AMD opteron but I am not quite sure about it.
any idea ? |
Posted: Wed Sep 16, 2020 11:25 am Post subject: |
Is the black painted on (will a solvent remove it to show any markings)? _________________ My graphics card database can be found at http://www.gpuzoo.com.
sebskyman
Posted: Wed Sep 16, 2020 11:54 am Post subject: |
not painted: I have used isopropyl alcohol and it did not remove the colour...
the caps is made of metal ( cold when you touch it)
It is pinless but contact points are similar than an Opteron ( see attached picture : this CPU vs AMD Opteron)
crazybubba64
Posted: Wed Sep 16, 2020 11:55 am Post subject: |
Could be a socket blank/terminator to protect the LGA pins when an actual CPU is not present? _________________ My collection |
Posted: Wed Sep 16, 2020 12:04 pm Post subject: |
Looks like terminator for socket F.
E.g. for using one cpu in dual system. |
sebskyman
Posted: Wed Sep 16, 2020 12:06 pm Post subject: |
there is a label on the side ( half of it is under the caps) something like:
SIPRG.COM |
Posted: Fri Sep 18, 2020 4:33 am Post subject: |
| terminator for AMD opteron. |
