researching AMD processors
EIE(tm)
PostPosted: Wed Jun 28, 2006 10:47 am    Post subject: researching AMD processors Reply with quote
I am researching AMD processors.
Can anyone tell me what the suffix letters AFQ, AFR, etc. mean on the
K6-2 400AFR, K6-2 400AFQ, etc.?
You can reply to eie@execpc.com.
Thanks.
PostPosted: Wed Jun 28, 2006 11:10 am    Post subject: Re: researching AMD processors Reply with quote
http://www.cpu-world.com/info/id/AMD-K6-identification.html#K6_2_and_K6_III
chrissie
PostPosted: Wed Jun 28, 2006 11:10 am    Post subject: for information take this link Reply with quote
Have also a look at www.cpu-galerie.de. You will find 6200+ different PC-Processors, 3400+ different are pictured.
EIE(tm)
PostPosted: Wed Jun 28, 2006 11:21 am    Post subject: researching AMD processors Reply with quote
Thanks, chrissie...that did it.
