Hatrick Guest
Posted: Thu Aug 24, 2006 6:13 am Post subject: Processor |
Hello.
My mainboard supports an AMD AthlonXP/Athlon/Duron processors,supports 200/266 MHz Front-Side Bus(all this out of handbook)also states has Socket-462 for AMD K7 processor,can anyone enlighten me as to a modern processor which would fit into the 462 socket,or any other alternatives available.Thank you in hope.  |
picur10
Joined: 22 May 2006 Posts: 1229 Location: Budapest, Hungary
Posted: Thu Aug 24, 2006 8:04 am Post subject: Re: Processor |
| I think the fastest Socket A cpu is Barton 3200+ |
Posted: Thu Aug 24, 2006 8:16 am Post subject: |
The fastest desktop processor for 266 MHz front-side bus is Athlon XP 2600+ AXDA2600DKV3C. It may be difficult to find it at good price, so you may consider upgrading to Athlon XP 2400+. Make sure that your motherboard and BIOS support these processors before the upgrade.
There are mobile Athlon XP-M processors that are faster than Athlon XP 2600+. If I remember correctly the fastest mobile Athlon XP-M with 266 MHz FSB is Athlon XP-M 3000+. It's based on different core (Barton), and it has lower core voltage, so your motherboard may or may not support it.
jd
Posted: Thu Aug 24, 2006 10:07 am Post subject: |
....Athlon XP-M 3000+@266 FSB (AXMA3000FKT4C)..is indeed the fastest one available for socket462 at 266FSB.For a better performance overall in the mobile category of the 266FSB, I'd go with the 2800+(AXMA2800FKT4C). It was well knowned for it's overclockable ability and stability,and of course performance.
As for destop cpu, I'd go with a 2200+Athlon XP.They are good, and not hard to find.
__J____D_____ ____
My two cents |
Hatrick Guest
Posted: Fri Aug 25, 2006 5:48 am Post subject: Processor |
Hello Everyone.
Many thanks for your courtesy in replying to my post,invaluable advice,now have a solid base to work from.  |
