jackohelp Guest
Posted: Sat Nov 18, 2006 4:57 pm Post subject: socket 462 with an athlon xp2400+ cpu. |
| Is there an upgrade path with SSE2 support??? |
Posted: Sat Nov 18, 2006 5:28 pm Post subject: |
There are no socket 462 processors that support SSE2. You'll need to upgrade you motherboard and processor to AMD Athlon 64/Sempron 64 or Intel Pentium 4/Core 2.
Posted: Sat Nov 18, 2006 5:42 pm Post subject: |
| any recommends at £100-£200 mark?? |
Posted: Sat Nov 18, 2006 6:48 pm Post subject: |
| Anonymous wrote: | | any recommends at £100-£200 mark?? |
I don't know UK prices, so I will assume they are the same as in US. For £100 or a bit higher I would go for socket AM2 single-core Athlon 64 3500+ or 3800+. If you want to spend close to £200 then, in my opinion, Intel Core 2 Duo E6400 would be the best. E6600 would be even better, but the E6600 CPU + board + memory will cost you more than $400.
jackohelp Guest
Posted: Sun Nov 19, 2006 3:18 am Post subject: socket462 |
| thanks, I will look into it. Anything else i need to watch out for? I realise i will need ddr2 ram, but i'm assuming all my drives, monitor, case + power supply will all work. It sounds too straight forward!! famous last words |
