suncu
Joined: 15 Sep 2006 Posts: 49 Location: Beijing CHINA
Posted: Sun Dec 17, 2006 2:04 am Post subject: Ask a problem? |
How distinguish the true or false of the PCPU3V100 SZ996 processors?Test?See FPO number?Still use other methods?Thanks
Posted: Mon Dec 18, 2006 7:32 am Post subject: |
My first step (if a visual inspection doesn't give a conclusive answer) would be to test the CPUID value. If that is right and I was still not sure, I would compare the FPO and other numbers with those on other, known good chips.
CPUID is always my first step when testing any x86 chip, and if the value is correct I would assume it to be valid unless there is a good reason to suspect otherwise (and as differering text isn't always as good an indicator as one might think, I would suggest the FPO number to be the second thing to compare with known good chips).
If a chip is dead, then I guess a visual inspection is about the only way to test (but it will always interest me to hear about other methods that don't involve destroying the chip to inspect the core). _________________ My graphics card database can be found at http://www.gpuzoo.com.
suncu
Posted: Mon Dec 18, 2006 9:31 am Post subject: |
Your meaning is to use the CPUID software, this software can test the model number of the processor, the processor family, cache, the clock frequency and manufacturer.
OK~~~Very thankful  |
suncu
Posted: Mon Dec 18, 2006 7:50 pm Post subject: |
| hugo929 wrote: | hi,suncu.don't u know the CPUID indentification method.  |
Old friend, the express delivery was slow to order last week, excusing me very  |
maoxuezhu
Joined: 08 May 2006 Posts: 82 Location: Beijing, China
suncu
Posted: Wed Dec 20, 2006 1:18 am Post subject: |
| chiptalk wrote: | | An easy way I quickly spot Chinese fake Pentiums is by the (R) in the logo. 90% of the Chinese Pentium fakes I have seen have an r like "R" (the bottom slant is 45 degrees, and not curved). |
Observe carefully, discover the R is really different.  |
suncu
Posted: Wed Dec 20, 2006 9:04 pm Post subject: |
| Thank CHIPTALK |
