Core 2 Duo & framerate
PostPosted: Wed Jan 03, 2007 5:14 pm    Post subject: Core 2 Duo & framerate Reply with quote
Hello,
I would like to know if upgrading my actual CPU, P4 630 (3Ghz) to a e6300 Core 2 Duo, I would gain some more frames in games. I also use a Leadtek 7900Gs PCIe videocard, 1Gb DDR2 and a SATA2 HDD. In games like Oblivion, FEAR, I have a good framerate, not extraordinary but ok. But in new games like Rainbow6 Vegas my framerate is a little bit poor so I also think of future games that will bring the same issue.
Thank you.
jd
PostPosted: Thu Jan 04, 2007 12:30 pm    Post subject: Reply with quote
..more info on Rainbow 6 Vegas.(posting this for others to understand the requirements.)
System Requirements:
Supported OS:Windows XP (only)
Processor:P4 3Ghz or AMD equivalent
RAM:1024 Mb
Video Card:128MB, Shader Model 3 and DirectX 9.0c compatible
Sound Card:DirectX 9.0c compatible
DirectX Version:DirectX 9.0c
CD-ROM:DVD-ROM 4X
Peripherals Supported:
Mouse, keyboard, headsets, Xbox360 Controller, etc.
Multiplay:
Local area network (LAN) and/or 128kbit Cable/DSL connection for online game
JD
PostPosted: Thu Jan 04, 2007 1:55 pm    Post subject: Reply with quote
Is there a hiden answer in your reply, JD? I cannot find an answer to my question. Could a Core 2Duo (e6300) give me a faster frame rate than my actual cpu?
PostPosted: Thu Jan 04, 2007 2:57 pm    Post subject: Reply with quote
It should, yes
jd
PostPosted: Thu Jan 04, 2007 7:22 pm    Post subject: Reply with quote
Laughing
Yes, this is the "hidden" answer you'll find vs the system requirements .
Obviously, if you up your CPU past the requirements of 3gig ,then it should work better. But I'm curious about something...What if you'd up your memory instead?
JD
PostPosted: Fri Jan 05, 2007 2:43 am    Post subject: Reply with quote
Yes, I will up my memory too, but first I was thinking about the CPU. The problem is that I've upgraded my video card from 7600gt to this 7900gs and there was just a little difference in framerate. So I would like to make another upgrade to have a better framerate. And I could thing only about the CPU, am I right?
jd
PostPosted: Fri Jan 05, 2007 10:39 am    Post subject: Reply with quote
...I say yes...(to the cpu upgrade).
But I'm always sceptical about the other things like, refresh rate of a monitor and the vid settings in the game itself ! As all games have default settings, like when I play Halo CE online, I had to tweak the Video settings and refresh rate in order to have the same "gameplay" results as my other games.
Just another few things to look at in my checklist of things to do before I spend more $ on parts ! Wink
JD
