steve Guest
Posted: Wed Mar 14, 2007 11:14 am Post subject: Overclocking a intel 975 |
| What is the best setup for overclocking? and what is the best software for checking cpu speed? |
Posted: Wed Mar 14, 2007 11:18 am Post subject: |
Cpuz, browse it. Good for cpu info.
Real time clock etc.
Have fun.
975 is the name of the chipset. Depends on your hardware. Browse for an overclocking tutorial.  |
steve Guest
Posted: Wed Mar 14, 2007 12:08 pm Post subject: Overclocking a intel 975 |
| Hey thanks! My board is a D975xbx2 with a 2.4ghz 2 core just wanted to know what the best setting were to overckock it to 3.0 ghz |
Posted: Wed Mar 14, 2007 12:23 pm Post subject: |
Sorry, for oc you must read a tutorial, try googling for overclocking and your cpu name, you'll find plenty I guess.
Normally you have to check the fsb, accordingly with your ram speed and pci/agp/pci-ex.
If you raise the fsb and alla the components like pci too much you can fry your hds, so read tutorial and learn!
Alone is sometimes better... |
steve Guest
Posted: Wed Mar 14, 2007 1:01 pm Post subject: |
Thanks!! I found an article that showed me the best benchmarks
and they were stable It was on Neoseeker.com Thanks again!!! |
Posted: Thu Mar 15, 2007 1:19 pm Post subject: |
cpu speed isn't most iportant after overclocking. You must be sure that computer will be stable at work. To check that I recommend Prime95
To have fun with PC and check current speed and many other interesting informations I recommend : Everest and SiSift Sandra. _________________ Visit ABC CPU - Virtual CPU Museum. |
