changeing bus and clock speed on my GA-7VTXH+ motherboard
dirtfarmer
PostPosted: Fri Mar 16, 2007 10:50 pm    Post subject: changeing bus and clock speed on my GA-7VTXH+ motherboard Reply with quote
i have a question about changeing bus and clock speed on my GA-7VTXH+ motherboard
im soon to change a CPU on my compter
from a
AMD Duron 1000 Speed (MHz) 1000
Bus frequency (MHz) 100
Clock multiplier 10
to a
AMD Athlon XP 2400+
Speed (MHz) 2400 (rated)
2000 (real)
Bus frequency (MHz) 133
Clock multiplier 15
bus will change from 100 to 133 MHz, and the clock multiplier will all so change from a 10 to a 15
my question is i notice ther a seting default ck_ratio is set on auto and clk_sw is set default on 100,, well i know i have to change the dip switch from 100 to 133, but what does the auto mean, does it mean when i change the cpu, it will auto change, the multiplier
Unzlbunzl
PostPosted: Sat Mar 17, 2007 4:00 am    Post subject: Reply with quote
should do so
PostPosted: Sat Mar 17, 2007 3:39 pm    Post subject: Reply with quote
exactly
Update BIOS to latest version before upgrade CPU. 2400+ will work check :
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ClassValue=Motherboard&ProductID=1313&ProductName=GA-7VTXH+
dirtfarmer
PostPosted: Mon Mar 19, 2007 7:22 pm    Post subject: thank for the rely Reply with quote
yes i been to the site all really- to see if what cpu i could use
\i was after a 2600 but ther are 2 model, at differnt bus speed and seen to be in demand, but it only 133 MHZ fasted then the 2400
not much really to worry about
and also i have update my BIOS to a F5, ther have a F6a beta, but the way it look gigabyte not going to finish it, so im not touching it
