mitch008
Posted: Sat Nov 03, 2007 3:49 am Post subject: Q6600 oc, and now only x6 multi works |
Hello
i have a big problem. My q6600 only works with multi x 6 , no mather which multi i set in BIOS, and with EIST (intelspeedstrap) enabled or disabled, it is allways the same... 6x XXX ( did anyone ever heard of that kinda cpu malfuntion, or is it something else wrong with the computer) ? |
Posted: Sat Nov 03, 2007 1:22 pm Post subject: |
what diagnostic program do you use to display the CPU data?
I have an Q6600 in my computer. It runs with 9x multiplier but CPU-Z shows only 6x !!!
BIOS and benchmark / test software show the correct settings.
If you are using Windows XP try to run dxdiag.
- If your CPU runs with correct clock multiplier you will see this on the first page.
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40 GHz (4 CPUs)
If the chip runs with 6x multi you will see something like this:
Intel(R) Core(TM)2 Quad CPU Q6600 @ 1.60 GHz (4 CPUs) |
