Posted: Thu Jul 30, 2009 11:07 am Post subject: problem of internet sharing by ADSL |
Hi, I encountered a very strange problem when sharing internet by ADSL.
My server has two net adapter cards installed.
One card is connected to ADSL modem and the other net card is connected to a HUB which connecting more computers in LAN.
The ADSL modem has a telephone line connected to my local ISP.
Now the problem is :
It works great without connecting to HUB.
But once the RJ45 is pluged into to the HUB, then the internet becomes unavailable immdiately.
Who can give me some advice.
It is very annoying. I googled but found no lukcy solution.
Thanks in advance!
Hugo _________________ My vintage CPU collection:www.cpumuseum.com
Chinese Forum: http://www.cpumuseum.com/forum |
Chiefish
Posted: Thu Jul 30, 2009 11:28 am Post subject: |
Go out and spend $20 on a cascading hub, plug youre dsl into the hub and all the rest of the machines into the hub and all problems will be solved. I would guess that the host server is getting confused in which network it should be connecting to. But I am not a networking expert. I have however had up to 8 machines hooked into one cascading network hub and they all connect directly to the internet with there own internal IP numbers without any trouble. _________________ "The only reason for time is so that everything doesn't happen at once." A.E. |
Posted: Thu Jul 30, 2009 11:38 am Post subject: |
| Chiefish wrote: | | Go out and spend $20 on a cascading hub, plug youre dsl into the hub and all the rest of the machines into the hub and all problems will be solved. I would guess that the host server is getting confused in which network it should be connecting to. But I am not a networking expert. I have however had up to 8 machines hooked into one cascading network hub and they all connect directly to the internet with there own internal IP numbers without any trouble. |
Sorry, I dont make it clear.
My server act as a proxy server, and all other computers in LAN is via this proxy server to internet. _________________ My vintage CPU collection:www.cpumuseum.com
Chiefish
Posted: Thu Jul 30, 2009 12:04 pm Post subject: |
Than maybe you need to enable internet sharing on the host machine. _________________ "The only reason for time is so that everything doesn't happen at once." A.E. |
faber
Joined: 18 Dec 2006 Posts: 315 Location: Poznan, Poland
Posted: Thu Jul 30, 2009 3:05 pm Post subject: |
| Please show your routing table when you do not have Internet. (cmd - "route PRINT") |
Posted: Thu Jul 30, 2009 3:24 pm Post subject: |
| Can you access the Internet from your server when it's other network card is connected to the hub? |
Posted: Thu Jul 30, 2009 5:13 pm Post subject: |
| Chiefish wrote: | | Than maybe you need to enable internet sharing on the host machine. |
I installed a Proxy server software to provide internet sharing so I needn't to enable the built-in internet sharing function of windows XP. _________________ My vintage CPU collection:www.cpumuseum.com
Posted: Thu Jul 30, 2009 5:14 pm Post subject: |
| Marcin wrote: | | you are connecting with not crossover cables to hub ? |
I am not sure with crossover or not. but is it a problem ?  _________________ My vintage CPU collection:www.cpumuseum.com
Posted: Thu Jul 30, 2009 5:18 pm Post subject: |
| faber wrote: | | Please show your routing table when you do not have Internet. (cmd - "route PRINT") |
It print lot of thing and I cannot grasp what it is complaint  _________________ My vintage CPU collection:www.cpumuseum.com
Posted: Thu Jul 30, 2009 5:19 pm Post subject: |
| Qwerty wrote: | | Can you access the Internet from your server when it's other network card is connected to the hub? |
I exchanged both cards but the problem remains _________________ My vintage CPU collection:www.cpumuseum.com
faber
Posted: Fri Jul 31, 2009 1:21 am Post subject: |
| hugo929 wrote: | | faber wrote: | | Please show your routing table when you do not have Internet. (cmd - "route PRINT") |
It print lot of thing and I cannot grasp what it is complaint  |
you can redirect command output to a file "route PRINT > c:\route.txt" and insert content of c:\route.txt here.
I suspect that you have the wrong default route. |
Posted: Fri Jul 31, 2009 1:22 am Post subject: |
Faber's suggestion is most helpful. I fixed the problem using "route" cmd to modify the routing tabel
Thanks _________________ My vintage CPU collection:www.cpumuseum.com
