1971 - 1101 Memory IC
Goto page 1, 2, 3  Next
tlccomp
PostPosted: Sun Jul 03, 2011 10:36 am    Post subject: 1971 - 1101 Memory IC Reply with quote
Got these the other day. Trying to ID the manufacturer.
The two most common elements on Earth are oxygen and stupidity.
PostPosted: Sun Jul 03, 2011 10:51 am    Post subject: Reply with quote
!!!! so earlyyyyy But sure is 1101mem chip ???
very nice if is !!!
tlccomp
PostPosted: Sun Jul 03, 2011 11:15 am    Post subject: Reply with quote
very nice if is !!!
Reasonably sure. It "fits" along with the other items that I received in the same group of IC's.
I suspect the logo may be a from a company named CMI (Computer Microtechnology, Inc.). I found a reference in a technical paper regarding LSI memories.
"This circuit is used in most of the 256-bit decoded MOS RAM'S manufactured by Intel, lntersil and Computer Microtechnology." And, Computer Microtechnology Inc. was involved with AMS
(Advanced Memory Systems) and was eventually bought out by AMS in 1973.
Elar
PostPosted: Sun Jul 03, 2011 12:24 pm    Post subject: Reply with quote
Not the first time this logo has come up:
http://www.cpu-world.com/forum/viewtopic.php?t=13083
PostPosted: Sun Jul 03, 2011 12:29 pm    Post subject: Reply with quote
there was an same 1101 sample chip.....
i think if u have some more of this u must sacrafise one ..to see if inside is really ram or some ttl logic of the early 70's...
if this is real ram..is very very uniq-important find....
I love mysteries...like theese....
tlccomp
PostPosted: Sun Jul 03, 2011 12:35 pm    Post subject: Reply with quote
Thanks for the reference. I think the logo could be CMI. Chiefish's picture is more clear. I have others looking into this as well.
tlccomp
PostPosted: Sun Jul 03, 2011 12:37 pm    Post subject: Reply with quote
Maybe I'll have to do that. Have one here that has bad corrosion from the black foam it was stored in.
PostPosted: Sun Jul 03, 2011 12:41 pm    Post subject: Reply with quote
So..i think worth to see inside...
keep us informed
thnx
PostPosted: Sun Jul 03, 2011 12:47 pm    Post subject: Reply with quote
should be made on 10micron so should not be too hard to see die features and markings.
PostPosted: Sun Jul 03, 2011 12:49 pm    Post subject: Reply with quote
yes even witha nicemagnify glass or a poor microscpe..... the intergration in 1971 wiil be rediculus for the today standards Smile
tlccomp
PostPosted: Sun Jul 03, 2011 1:00 pm    Post subject: Reply with quote
Any suggestions as to the best way to remove the lid?
Elar
PostPosted: Sun Jul 03, 2011 1:19 pm    Post subject: Reply with quote
Our member naked1300 shows how:
http://www.cpu-galaxy.at/Article/opening_die_core.htm
PostPosted: Sun Jul 03, 2011 1:25 pm    Post subject: Reply with quote
i think a well cutting razor will do the job without mutant the die core from the heavy temp...is nt big chip like 486..ect......
try something soft......evena cuting tool for wires do the job i have open 10's ic like this with this way...
PostPosted: Sun Jul 03, 2011 1:28 pm    Post subject: Reply with quote
8megapixel + camera with macro focus will see everything ya want to see as welll
tlccomp
PostPosted: Sun Jul 03, 2011 1:50 pm    Post subject: Reply with quote
Thank you for the link Elar. First attempt... may need to borrow a better camera.
Page 1 of 3
