donutty
Posted: Sat Dec 06, 2008 4:55 pm Post subject: Military hybrids |
Military Thermal Imaging PCB (Marconi Avionics Limited).
All ICs and hybrids are socketed.
Anybody know what they are??
Underneath all the hybrids have thermal paste, so they must generate quite a bit of heat. The whole PCB is metal clad and acts as the heatsink.
Higher resolution: http://www.nitrate.plus.com/Files/Pics/L6A1_hybrids.JPG |
Posted: Sat Dec 06, 2008 7:55 pm Post subject: |
I have never get connected to nitrate.plus.com. possibly been blocked by firewall as well  _________________ My vintage CPU collection:www.cpumuseum.com
Chinese Forum: http://www.cpumuseum.com/forum |
Posted: Sat Dec 06, 2008 10:08 pm Post subject: |
Bloody cool board, Adam!
Can you sell any of these to members?  |
Joined: 04 Apr 2008 Posts: 3364 Location: Chicago, IL- US
Posted: Sat Dec 06, 2008 10:09 pm Post subject: |
My message above---darn Login...  |
donutty
Posted: Sun Dec 07, 2008 6:07 am Post subject: |
| Hugo - does that mean you can't see the picture above? If so, I'll put the pictures somewhere else. |
donutty
Posted: Sun Dec 07, 2008 6:24 am Post subject: |
| CPUShack wrote: | | I kinda wonder if thr RCA part isnt a custommarked 1802? and a ROM next to it. |
If I had a COSMAC board, I'd test it!
Maybe I will reference it against an 1802 and check the resistances across pins to at least get some idea. That gives me an idea for an IC cross-referencing tester:
Using a microcontroller and and ADC, you put the reference IC (the one that you know is a genuine article) in the socket and the uC reads the resistances from each pin to the next (or from GND to each pin) and stores them. You take the reference chip out and put in the 'unknown' one. The same test is repeated and the results compared (within a certain percentage margin either way).
What do you think? |
doccybrown
Posted: Sun Dec 07, 2008 8:36 am Post subject: |
| donutty wrote: |
Sounds good, you should also test all pins against
Vcc to identify tri-state outputs and other specialities...
I normally do this job manually with a multimeter,
diode-testing position to have at least 2Volts for checking.
Made very good experiences and this is way better than
scrapping any very rare 1802-running device by
putting in an unknwon millipede....
Cute board!  _________________ Ordem e Progresso |
