Interesting die shots
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips
Chiefish
PostPosted: Tue Nov 24, 2009 9:44 pm    Post subject: Interesting die shots Reply with quote
I was bored tonight and decided to take out my microscope to look at some die shots pf some of the old Intel eproms I have and discovered that a 1701 grey and a 1702 grey have the exact sme markings on them . I also have an early grey 1702a and took a look at that die and heres what I found. What is the difference between the 1701 and the 1702 , or does anyone know any visible differences between the two to look for? the last shot is of a 1702a grey,Just for the hell of it I also looked at a Micro Intl 1701 i have.
"Technological progress is like an axe in the hands of a pathological criminal." A.E.
Check out my collection at http://www.chiefish.com/
Chiefish
PostPosted: Tue Nov 24, 2009 9:45 pm    Post subject: Reply with quote
heres the shot of the Micro Int 1701, and a c1702a
PostPosted: Wed Nov 25, 2009 1:33 am    Post subject: Reply with quote
The four devices 1601, 1602, 1701, and 1702 use identical chips. The 1601 and 1701 is operable in both
the static and dynamic mode while the 1602 and 1702 is operable in the static mode only.
In the beginning of 1970 the market needs for this chip was enormous but the yield of the first 1702
production was very poor. On each functional chip there were hundreds of unusable chips. After
modification of chip architecture from parallel in serial design and including the Walkout (put the chips
under high negative voltage) into the manufacturing process the production yield suddenly increased to 60
chips per wafer. After modification of this production process the chip was marked 1702A
***I Aim to Misbehave.***
dume
PostPosted: Wed Nov 25, 2009 7:39 am    Post subject: Reply with quote
Interesting.
Great pics.
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips All times are GMT - 5 Hours
