CPU Shack: New In Package 486 CPU Upgrade Adapter - SOLD
PostPosted: Mon Feb 26, 2018 6:39 pm    Post subject: CPU Shack: New In Package 486 CPU Upgrade Adapter - SOLD Reply with quote
Kind of a cool piece of history.
Here is an upgrade adapter socket for the 486, allowing 486s such as the AMD and Cyrix 5x86 and Intel DX4-100 to be used in old 5V systems
Still in the package
$18
PostPosted: Mon Feb 26, 2018 6:42 pm    Post subject: Reply with quote
I'll take it !
PostPosted: Mon Feb 26, 2018 7:15 pm    Post subject: Reply with quote
If you find another I would take it.
feipoa
PostPosted: Mon Feb 26, 2018 11:53 pm    Post subject: Reply with quote
I realise its gone, but do you have a pin-side photo? If the bottom is without IC's, what I like about this adapter is that it doesn't contain additional logic chips. A lot of these upgrade adapters contained PAL or GAL IC's, which I think are added to increase compatibility in some situations. Not knowing exactly what those IC's are doing bothers me. What is they are written for the Cyrix 5x86 in mind but you want to use an Am5x86, or visa-versa.
I keep staring at Table 1 and continue to have no idea what information it is trying to convey.
As for Table 2, I didn't realise the Intel DX4 could run at 2.5x the FSB. Can it?
The only thing I hate more than straightening CPU pins is having CPU's with bent pins in my collection.
WFS2005
PostPosted: Tue Feb 27, 2018 12:12 am    Post subject: Reply with quote
It is look different my
My CPU collection: www.T-CPU.com
PostPosted: Tue Feb 27, 2018 12:20 am    Post subject: Reply with quote
Table 1 is saying essentially the same thing as Table 2, but based on the initial system clock (if you have a DX-25 set the jump to 2-3 for the AMD etc)
Pin Side
H3nrik V!
PostPosted: Tue Feb 27, 2018 2:48 am    Post subject: Reply with quote
So, basically, it's a voltage regulator and a multiplier selector .. ?
kixs
PostPosted: Tue Feb 27, 2018 2:55 am    Post subject: Reply with quote
It's just an adapter... and I want a few Wink
feipoa
PostPosted: Wed Feb 28, 2018 1:47 am    Post subject: Reply with quote
Its really nice how clean it is from any IC's. I have one from Trinity Works (the Power Stacker), one from Evergreen, and one from Gainbery. They all have IC's aside from the voltage regulator. The only module I have without IC's is an Evergreen unit which contained a QFP Am5x86-133, plus caps, and a VR IC. I'm sure there are more PGA-socketed adapters like this, but I haven't run into one in person without any ICs.
It really makes me wonder how much benefit the IC's provided and if they in some cases they caused more compatibility issues rather than fixes.
H3nrik V!
PostPosted: Wed Feb 28, 2018 2:08 am    Post subject: Reply with quote
I'm so curious now .. Smile
Would someone start a thread in another section of the forum with pictures of interposers?
feipoa
PostPosted: Wed Feb 28, 2018 3:06 am    Post subject: Reply with quote
If you start it, I will post photos of the ones I have. Please post the thread link here.
H3nrik V!
PostPosted: Wed Feb 28, 2018 5:16 am    Post subject: Reply with quote
http://www.cpu-world.com/forum/viewtopic.php?t=30354
Not sure if it's the right section, though Laughing
iPonRMA
PostPosted: Wed Feb 28, 2018 3:53 pm    Post subject: Reply with quote
Maybe Hugo's one still available:
https://www.ebay.com/itm/vintage-rare-collectible-AMD-A80486Dx2-66-CPU-with-adapter-gold-scrap-/273023403468?nma=true&si=jtCFcOE%252BoYD34UI%252B93fid3mrGHo%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
black_monolith
PostPosted: Tue Mar 13, 2018 8:35 am    Post subject: Reply with quote
I have a few of the modules pictured. They are nice in that they have a small profile, but I don't like how they placed the VRM under the CPU. It would have also been nice if there was a WB/WT jumper.
feipoa
PostPosted: Tue Mar 13, 2018 3:17 pm    Post subject: Reply with quote
Because of heat dissipation issues, esp. when using a linear regulator?
