Anything worth warming up the heatgun for?
PostPosted: Wed Feb 08, 2006 12:06 pm    Post subject: Anything worth warming up the heatgun for? Reply with quote
Anyone seeing anything remotely collectable?
/T
PostPosted: Wed Feb 08, 2006 12:40 pm    Post subject: Reply with quote
before you do, I noticed one ebay seller left the chips on the pcb, looks like he used a bandsaw to cut the board up. I was thinking that would be a nicer way ( if the cuts were good) of displaying some chips ( lik ethe laptop cpus on the small pcbs), rather than heating it up and taking it off the board.
sammyc
PostPosted: Wed Feb 08, 2006 1:10 pm    Post subject: Reply with quote
acutually a good idea if it is done professionally and not hacked!
4000+ chips.
4004-P4.
PostPosted: Wed Feb 08, 2006 1:11 pm    Post subject: Reply with quote
yeah, those surface mount chips look much better "in the environment" than they do removed with solder blobs on their legs and bent pins.
PostPosted: Wed Feb 08, 2006 1:12 pm    Post subject: Reply with quote
oh, and cpuswe, those are some really cool chips Smile
PostPosted: Wed Feb 08, 2006 1:22 pm    Post subject: Reply with quote
I totally agree. It's good to keep the chips on a piece of board if they have been used (obviously not if they are new chips), but cutting the boards needs to be done properly. I have an AMD NG80386SX/SXL-25 that was cut off the board, and it was done so badly that about half 90% of the pins have been cut (all are still attached to the board, just not as well as before the cut). Only reason he got away with it was that I have no other AMD 386SX in any package...
PostPosted: Wed Feb 08, 2006 1:28 pm    Post subject: Reply with quote
a bandsaw is the job.. but wear a mask and goggles.. and dont go cutting through any components if possible.
PostPosted: Wed Feb 08, 2006 5:43 pm    Post subject: Reply with quote
What I think : letting a cpu on a small piece of PCB sucks.
Most of time it is not clean, and it is definitely not the original environnement anymore...
But I think I'm the only one to think so...
For PQFP, hot air gun is very clean -> no bent pin, no solder remaining or just a little, not easy to see
For BGA -> nothing to do, nothing will be clean.
