CHips
Posted: Mon Mar 02, 2026 2:04 pm Post subject: Cpu Adapters/Mods Compilation (SlotKets, etc) |
I wanted to compile a list of known Adapters or similar, and speculate about what could Exist...
Post if you have seen some Existing Combinations missing here or thought non existent, or your opinion on whether an unknown Combination could be possible :p
Or just to share your experience using one of these
Format: Cpu Socket -> Motherboard Socket
Known Adapters
Socket 370 -> Socket 8: Extremely Rare, examples in some Japanese News, on Vogons
Socket 8 -> Slot 1: Very Rare, Asus C-P6S1 and few other Models, there are also Clones out there so could become easier to find, but no idea where the Project went since then.
Socket 370 -> Slot 1: ubiquitous... though Tualatin Capable ones like the PowerLeap PL-iP3/T are Rare.
Slot 1 -> Slot 2: Epox EP-S2C and one or some Others, Extremely Rare.
Socket 478 -> Socket 423: can occasionally be found, even here
Socket 479 (Pentium M) -> Socket 478 (Pentium 4): Very Rare Asus CT-479 (not working on many Motherboards), not aware of another Model
Socket 478 (Pentium 4) to Socket 775: something called "Socket 775 to 478 CPU Adapter"/PTCA-01, Extremely Rare. Notably used to test SL7QB/SL7Q8s here
Socket 5/7 -> 4, Unconfirmed
Not Adapters but Known Mods
Bga Pentium 2 -> Socket 370 like this Pentium 2 267
Modding Socket 771 Cpus to make these work on 775 is well known (the other way should be possible too I guess? but never heard of that since it is less interesting I suppose...)
Mods/Fakes of Mobile Pentium Mmx to Socket 7 are well known.
Core Gen 2-9 Mobile Bga to the respective Mobile or Desktop Pga Mods Exist (for example, QJR9s have been Modded to work on 1151)
There are some Mods to Run Intel Core 8xxx or 9xxx on 6xxx or 7xxx Motherboards
Atom -> 775 Mod appears to Exist, have yet to see some proof that it works.
Other similar known Upgrades or Oddities
486 on 386 Platform: RapidCad and some other Non Intel
Pentium on 486 Platform: Pentium OverDrive 63/83
Pentium 2 on Pentium Pro Platform: Pentium 2 OverDrive 333
Some AsRock Socket A Boards allowed you Upgrade to 754 via the 754Bridge
Some AsRock 754 Boards allowed you Upgrade to 939 via the 939CPU Board
There were also 939 Boards allowing Upgrade to Am2 via the AM2CPU Board (these also worked for Upgradeable 754 Motherboards it seems since they say "from socket 754/939 to socket 940(AM2)")
Sandy/Ivy Bridge 1155 on Nehalem/Westmere Platform: Intel SIBX_CRB (Prototype)
Nehalem/Westmere 1156 on Sandy/Ivy Bridge Platform: AsRock P67 Transformer
Crossflashing or Modding Bioses may make Broadwell work on 8 Series Chipset
Some Chipsets for consumer and mobile CPUs (H, Q, B, Z series etc) can run HEDT/Xeon E5 chips if the motherboard is designed around them
Supposed to Work without Adapter nor Mod (if Bios Compatible)
Socket 5 Cpu on Socket 7 Motherboard
Socket 603 on 604
Socket Am3 on Am2 or Am2+
Have not heard of those, some are silly or physically cumbersome and certainly do not exist but are probably possible considering existing Adapters or Platform Designs?
Assuming any fixable issues like missing Microcodes or Voltages are taken care of.
386 on 486 Platform?
Timna on Regular 370 or the other Way?
Socket 615 or Socket 479 (Pentium 3 Mobile) -> Socket 370: should be possible since Bga Pentium 2 -> Socket 370 Exists?
Socket 478 (Pentium 4) -> Socket 479 (Pentium M): why not since the other way is possible with the Ct-479?
Socket 423 -> Socket 478 or even 775: since 478 -> 423 Exists, so could the other way? And then, since 478 -> 775 Exists too, 423 -> 775 should be possible? And also the inverse directions? Let's Run Cedar Mills or even Pentium Ds on 423 Lol; getting Nx for Windows 10 or 11 Support on 478 or even 423 would be some Grail that have been pursued by some people!
Socket 479 (Pentium M) -> Socket 775: should be possible since we can do 479 -> 478 and 478 -> 775? Is there anyone in this world having both the Ct-479 and Ptca-01?
Atom -> 478/479 (Pentium 4/M) Interposer?
Socket A -> Slot A just like Socket 370 -> Slot 1? How come there are so many Socket 370 -> Slot 1 but nothing for the As?
Am2(+) -> Am3?
Slot 2 -> Slot 1?
478 <-> 603/604?
604 -> 603?
Other Mobiles Bga -> Mobile/Desktop Pga or Mobile Pga -> Desktop Pga?
Any theoretical possibility for these?
Anything between Socket A, 754, 939, 940 or Am2 besides these specific AsRock Boards? Something like the 478 -> 423 Adapters?
Anything between the 115x? Again as Adapters rather than Platform of Different Gen Chipset.
Am3 <-> Am4 <-> Am5?
Anything Else?
Should be Impossible.
or similar to recreating a whole Motherboard on top of the Socket, but that would be Cheating Lol
486 <-> Socket 4 or 5/7 ❌ 32 vs 64 bit bus
Socket 5/7 <-> Socket 8, 370, A, Slot 1 or A ❌ Bus signaling vastly different
Socket 370 <-> Socket 423 ❌ Bus signaling vastly different _________________ Stelo.xyz Museum (CPU Collection and more)
Wasmachineman_NL
Posted: Mon Mar 02, 2026 3:35 pm Post subject: |
>I cannot find it anymore but I am pretty sure to have seen a Sandy Bridge work on 1156 (or was it the other way?)
Other way around, P67 Transformer. There's one for sale on Marktplaats right now actually. |
Glory_Cloud
Posted: Mon Mar 02, 2026 4:37 pm Post subject: PowerLeap PL-IP3/T and PS12437? |
Interesting, I just pulled ten Slot 1 to Tualatin adapters from
some Dell Opt1plex PC's. I have seen the PL-IP3/T V2.0's
before but I am unfamiliar with the PS12437's. Is it a
PowerLeap as well? I don't see a manufacturer on it.
It has an Intel SL6C8 Celeron processor installed on it. |
Posted: Tue Mar 03, 2026 3:53 am Post subject: Re: Cpu Adapters Compilation (SlotKets, etc) |
| CHips wrote: |
Yes. Quite easy. FPGA with glue logic needed to emulate the missing signal, but possible.
> 486 on Socket 4 or 5/7?
No. 32 vs 64 bit bus
> Socket 5/7 to 4?
Yes. Very complex. Will require very fast voltage translators and glue logic
> Socket 7 to Socket 8, 370, A, Slot 1 or A?
No. Bus signaling vastly different.
Maybe. Lack of datasheet on Timna.
> 370 <-> 423?
> Atom Bga Modded to Run on 775 like that Pentium 2 on 370?
Doesn't look impossible. _________________ ES-Only Collector : http://www.engineering-sample.com
Universal Chip Analyzer (UCA) : https://x86.fr/uca / http://www.cpu-world.com/forum/viewtopic.php?t=34349 |
H3nrik V!
Posted: Tue Mar 03, 2026 5:27 am Post subject: |
| IIRC there was some Celeron for socket 8 as well? |
crazybubba64
Posted: Tue Mar 03, 2026 2:53 pm Post subject: |
I would expect most of the core 2 and mobile CPUs (Socket M, Socket P, etc. both soldered and socketed) to be able to run in an LGA775 board with the right theoretical adapter (good luck mounting a heatsink though). All of those used the same CPUIDs as their desktop counterparts and behave VERY similarly.
A lot of the limitations on laptops were imposed by the bus speed offered by the chipset and power budget. Most desktop boards are flexible enough that it shouldn't be a limitation really.
I'd expect it to be similar to the more modern mobile CPUs soldered onto LGA interposers. _________________ My collection |
wren4777
Joined: 13 Dec 2016 Posts: 571 Location: Litija, Slovenia
Posted: Wed Mar 04, 2026 12:14 pm Post subject: |
| Wasmachineman_NL wrote: | >I cannot find it anymore but I am pretty sure to have seen a Sandy Bridge work on 1156 (or was it the other way?)
Nope, not just the other way around. I have an Intel Ibex Peak CRB that runs 1155 CPUs with a P55 chipset. I don't have pics handy, but here is my CPU-Z valid: https://valid.x86.fr/kpmjs2
Some other relevant info:
On the CPU-World Discord, a member bought an Atom on a 775 interposer sold by CPUShack, but I don't know if he ever booted it.
I've seen Original Xbox CPUs soldered to those BGA P3 to S370 interposers, but again, never seen one booted though I don't see why it wouldn't work.
I may be misremembering but I think one of the pioneers of the 771 to 775 mod did actually get 775 chips booting on 771. But I read this in an archived forum thread years ago so no clue if it's still up, if it's even real.
On the subject of the 775 mod: despite there being no released 775 chips with a 667Mhz FSB, some boards boot 667Mhz FSB 771 Xeons with zero problems. Probably because of QDZC, a cancelled 775 Netburst Xeon with a 667 FSB (holy grail for me, but never seen AFAIK). Valid of a 667Mhz 771 Xeon on 775: https://valid.x86.fr/b1c5hj
The Mobile 14nm chip to LGA 1151 mod isn't limited to the QJR9, many such chips are available on these interposers. I think even Comet Lake, but someone else will have to confirm. Alder Lake mobile to LGA 1700 also exists too.
Older BGA mobile chips have also been adapted to desktop sockets (2nd to 5th gen, 1st gen probably exists but I don't recall seeing one) and PGA mobile sockets (only up to 4th, because that was the last gen Intel had a mobile socket). 4th gen is specifically interesting for this mod, because Crystal Well CPUs with Intel Iris graphics and L4 cache were only officially released in BGA form. But with this mod you can run them on PGA laptops like I do on my Dell E6440: https://valid.x86.fr/j7i4eb
Not a socket mod, but certain 8 series 1150 boards that have similar PCBs to 9 series boards can be crossflashed with a 9 series BIOS to run Broadwell chips, if you disable Intel ME. Here is a valid of my Asrock H81 ITX crossflashed to H97: https://valid.x86.fr/2cn7u5
Similarly, chipsets for consumer and mobile CPUs (H, Q, B, Z series etc) can run HEDT/Xeon E5 chips if the motherboard is designed around them. Most of the Chinese X79/X99 boards actually use these chipsets, though it's hard to tell which of their weird issues are due to the chipset and which are because of motherboard design errors.
I think that's about all I can remember off the top of my head, but I will post more if anything comes to me.. thanks for starting the thread and making me remember all these fun things! _________________ My WTB List
My collection
Have a nice day!  |
Joined: 21 Jul 2016 Posts: 3589 Location: Netherlands
CHips
Posted: Sat Mar 07, 2026 8:02 pm Post subject: |
Cool, some nice replies, updated the first Post accordingly and added a few more theoretical combinations
Now I remember, it was that Topic from you Wren4777 that I thought about: https://www.cpu-world.com/forum/viewtopic.php?t=35789
I did actually misremember and thought that it was some Es Socket 1156 Sandy Bridge Cpu rather than a Gen 1 Platform with Socket 1155 Cpu (or the other way around as pointed by Wasmachineman_NL), but still interesting oddities!
Nice about the Atom on 775 Interposer, would take if there are some more Available...
Some Dual Core PineView like the D525 on 775 would be interesting for Benchmarks Vs Pentium 4/D or Core 2 on equivalent Platform rather than NetBook Vs Desktop or so...
And good replacements for the inefficient power hungry Pentium 4/Ds.
Considering 775 -> 478 should be Possible (since 478 -> 775 is), Atom on 478 should as well and would be really neat !
Have overlooked these Server Sockets and Slots, good find about the the Epox EP-S2C.
I guess 478 and 603/604 Platforms should be similar enough so some Adapter in the form of the 478 -> 423 or Ct-479 one would be possible... _________________ Stelo.xyz Museum (CPU Collection and more) |
Posted: Mon Mar 09, 2026 5:50 am Post subject: |
There is different a slot 1 -> slot 2 converter (with a switch to select the cpu slot) on ebay, don't know the brand but here are the pictures:
H3nrik V!
CHips
Posted: Wed Mar 11, 2026 3:53 pm Post subject: |
Well, that still counts as 370 -> 8...
Unless you meant some Socket 8 Celeron made like the Pentium 2 OverDrive, which I am not aware of and don't see anywhere in the Article. _________________ Stelo.xyz Museum (CPU Collection and more) |
H3nrik V!
Posted: Thu Mar 12, 2026 8:54 am Post subject: |
| CHips wrote: | Well, that still counts as 370 -> 8...
Unless you meant some Socket 8 Celeron made like the Pentium 2 OverDrive, which I am not aware of and don't see anywhere in the Article. |
Yes, it's still just an interposer. |
Posted: Fri Mar 13, 2026 7:22 am Post subject: S4 to 5 adapter |
While browsing stuff I found this and asked the seller.
It's a socket 4 to 5 adapter.
Can't say if it is really that though. |
H3nrik V!
Posted: Fri Mar 13, 2026 2:24 pm Post subject: Re: S4 to 5 adapter |
| D.8080 wrote: | While browsing stuff I found this and asked the seller.
Could easily be a voltage regulator under the heat sink and a bunch of logic level converters .. |
