upgrader001
Posted: Fri Aug 21, 2020 5:42 pm Post subject: laptop cpu upgrade |
Hi i have an Aorus 15 X9 with a i7-8750H as CPU. It is a compatible upgrade from this cpu to a I9-9980HK? It will work and run? Chipset: Intel HM370. Yeah, i know , its soldered, its's not an easy game. I don't want to do this by my hands, i want to buy or contract a service from a specialized technical service to do this. If it is possible, what kind of service i have to ask? Do I need a bios upgrade/update?
thanks |
crazybubba64
Posted: Fri Aug 21, 2020 6:10 pm Post subject: |
Possible in theory if the board's BIOS has the microcode and power delivery needed for the 9980HK.
After sourcing parts and labor, it may cost about as much as a new laptop with said CPU, so your mileage may vary. _________________ My collection |
upgrader001
Posted: Sat Aug 22, 2020 7:36 pm Post subject: |
| But how can I know if the microcode support 9th generation? |
upgrader001
Posted: Mon Aug 24, 2020 4:42 pm Post subject: |
| Hello someone is there? |
Calbris
Posted: Wed Aug 26, 2020 11:45 am Post subject: RE: laptop cpu upgrade |
If you don't want to do this with your own hands, does that mean everything is outsourced to a service? Such as the BIOS modification to add the appropriate microcode, and possibly testing it to verify that it actually works, etc?
Extract the BIOS image from the BIOS chip, or alternatively, download the BIOS image from Gigabyte/Aorus. If the BIOS image's microcode data isn't compressed, you should be able to read it with platomav's MC Extractor.
The output from MC Extractor will be very barebones, but it's sufficient for your situation as you simply need to check if there's an entry for CPUID 906ED. That is the microcode required for a Core i9-9980HK to run, but be aware that the platform ID must match as well (I'm not sure which is the right platform ID, so please don't ask me for it). _________________ CPU-World: Errors & Updates - https://www.cpu-world.com/forum/viewtopic.php?t=26667
Intel & AMD QS/ES Details - https://www.cpu-world.com/forum/viewtopic.php?t=36609
Info about rate limits on CPU-World - https://www.cpu-world.com/info/site/pv_limit.html
upgrader001
Posted: Wed Aug 26, 2020 4:04 pm Post subject: |
| Thanks people but the cpuid is 906ea. But...gigabyte released the aorus 15 xa with a bios that comes with the 906ed( even I saw the cpuids and it includes 906ea, not cpuid are the same platform). The question is, is it possible add the microcode from that bios? |
Calbris
Posted: Thu Aug 27, 2020 5:48 am Post subject: RE: laptop cpu upgrade |
Yes.
Via hex editors or a tool that is able to add the microcode without much work, such as MMTool.
I can't offer much help regarding this as your Aorus 15 has an AMI Aptio UEFI image, so you're on your own if you're planning to do the modification by yourself. |
Ezequiel
Posted: Tue Dec 29, 2020 4:15 pm Post subject: |
| Hello, I need to change the CPU of my laptop for a more modern and powerful one, the Socket is Intel BGA1023. Which CPU is compatible with this one? Any good one? Thanks |
crazybubba64
Posted: Tue Dec 29, 2020 6:39 pm Post subject: |
| Ezequiel wrote: | | Hello, I need to change the CPU of my laptop for a more modern and powerful one, the Socket is Intel BGA1023. Which CPU is compatible with this one? Any good one? Thanks |
Your CPU is soldered to the motherboard. In most cases it will be cheaper to buy a new laptop than attempt to upgrade it.
If you still want to pursue upgrades, you'd need to know the exact model of CPU and what your system is. _________________ My collection |
alehko
Calbris
Posted: Thu Jan 21, 2021 11:35 am Post subject: RE: laptop cpu upgrade |
You have three choices:
[1] Core i7-640M, SLBTN
[2] Core i7-620M, SLBTQ/SLBPD
[3] Core i5-580M, SLC28
These are the fastest dual-core processors available for Socket G1, which is what your Satellite U500 has. If the Core i7-640M is too expensive, you should look for a Core i5-580M or a i7-620M.
The Core i7-720QM and the other quad-core processors might not work in a Satellite U500. From my perspective, it seems very unlikely for it to work with a quad-core. I've never seen a factory configuration featuring any of them either. _________________ CPU-World: Errors & Updates - https://www.cpu-world.com/forum/viewtopic.php?t=26667
alehko
Posted: Fri Jan 22, 2021 7:41 am Post subject: |
| Calbris,thank you very much! Could you tell me what I should do to update step by step, if it does not bother you ) |
Calbris
alehko
Posted: Sat Jan 23, 2021 5:09 pm Post subject: |
Calbris,i am very grateful to you for your help !
I downloaded a new bios from your link.During installation, there was a problem. I double-click on the exe file. The program is installed on the C drive. Then a menu with three items appears.
https://ibb.co/7knyXkz
https://ibb.co/GQhTsRs
1 installation with cd-rom
2 installation using windows
3 instruction.
I select item 2 using Windows, then the command line appears and nothing happens.https://ibb.co/CnSJM2G
I left it in this position for 1 hour and nothing happens.
then I decided to try point 1 - with the help of cd-ROM and a blue screen appeared, the laptop rebooted and now the BIOS program does not start and gives an error.
https://ibb.co/TmQssmW
https://ibb.co/rdFdbLM |
alehko
