Calbris
Posted: Tue Dec 29, 2020 2:21 pm Post subject: Unsorted Intel S-Specs |
<Q-Specs & S-Specs list>
Alder Lake-S Refresh C0
? = Core i5-14401EF @ 4.7 GHz
? = Core i5-14401TEF @ 4.5 GHz
Q37X = Core i5-14500T QS
Q37Y = Core i5-14500 QS
Q381 = Core i5-14400T QS
Q3XZ = Core i5-14400 QS
Q1M8 = Core i5-13500TE QS
Q1M6 = Core i5-13500E QS
Q1JE = Core i5-13400E QS
Q1EP = Core i5-13400 QS
Q1EW = Core i5-13400F QS
QYMF = Core i9-12900E QS
QYMG = Core i9-12900TE QS
QYMH = Core i7-12700E QS
QYMJ = Core i7-12700TE QS
Alder Lake-S Refresh H0
? = 310 @ 4.1 GHz - https://browser.geekbench.com/v6/cpu/6867189
Q3E5 = Core i3-14100F QS
Q3E6 = 300 QS
Q3E7 = 300T QS
Q1N1 = Core i3-13100E QS
Q1N3 = Core i3-13100TE QS
QYYP = Core i5-12500E QS
QYYW = Core i5-12500TE QS
QYYV = Core i3-12100E QS
QYYS = Pentium G7400E QS
QYYT = Pentium G7400TE QS
QYYR = Celeron G6900E QS
Meteor Lake-S ES2 C0
Q46W = 6P+8E @ 4.5 GHz
Raptor Lake-S B0
Q37U = Core i5-14400F QS
Q1JB = Core i9-13900E QS
Q1JA = Core i9-13900TE QS
Q1JC = Core i7-13700E QS
Q1JD = Core i7-13700TE QS
Raptor Lake-S ES3
Q1BS
Q1BQ
Q1BR
Q1HM
Q1HP
Raptor Lake-S ES2
Q0D8
Q0D7
Q0DX
Q0WL
Q0PS
Q0UK
Q0UG
Q0UL
Q0UF
Q0WH
Q0WK
Q0WJ
Q0L5
Q0L9
Q0L7
Q0L4
Q0PV
Q0PU
Q0NT
Q0NW
Alder Lake-S ES3 - PCIE 5.0 x16 is functional
QYEH = 8P+8E+GPU @ 4.6 GHz
QY3A = 8P+8E+GPU @ 4.6 GHz
QY39 = 8P+8E+GPU @ 4.6 GHz
Alder Lake-S ES2 - PCIE 5.0 x16 is nonfunctional, DDR5-4800 boots fine
QYGE = 6P+GPU @ 4.6 GHz
QYGD = 6P+GPU @ 4.2 GHz
QYGC = 6P+GPU @ 4.4 GHz
QYFL = 6P+GPU @ 4.4 GHz
QY52 = 6P+GPU @ 4.2 GHz
QY50 = 6P+GPU @ 4.6 GHz
QXW5 = 6P @ 4.4 GHz
QXQ3 = 8P+8E+GPU @ 4.6 GHz
QXLB = 8P+8E+GPU @ 4 GHz
QXJE = 8P+8E+GPU @ 4.6 GHz
QXDY = 6P+GPU @ 4 GHz
QX7J = 8P+8E @ 4 GHz
QX7H = 8P+8E @ 4 GHz
QX7E = 8P+8E+GPU @ 4 GHz
Q8UH = 8P+8E @ 4 GHz
Alder Lake-S ES1 - PCIE 5.0 x16 is nonfunctional, DDR5-4800 might not boot
QXQ4 = 8P+4E+GPU @ 4 GHz
QXJB = 8P+8E+GPU @ 4 GHz
QWV0 = 8P+8E+GPU @ 3.4 GHz
QWK9 = 8P @ 2.4 GHz
Rocket Lake-S A0 ES1
QV2U = 2.8 GHz, 8C, DDR4-2666, 16 MiB L3, PCIE 3.0, 80 W, ECC
Comet Lake-S P0 ES2
QTB3 = 2.6 GHz, 10C, DDR4-2933, 20 MiB L3, PCIE 3.0, 80 W, ECC
Haswell-MB B0/C0 ES1 & ES2
CW8064701350603 QDEP
CW8064701473702 QDQD
CW8064701470803 QEDA
CW8064701486718 QET7
CW8064701486812 QET9
CW8064701474402 QEXZ
CW8064701486701 QF0P
CW8064701486719 QFAD
Ivy Bridge-MB
Cancelled: Core i3-3118M, Core i3-3128M, Core i3-3140ME, Core i3-3140M, Core i5-3350M, Core i5-3390M
Sandy Bridge-MB
Possibly: 2390M, 2470M, 2560M, 2660M, 2530QM, 2570QM, 2650QM, 2740QM, or 2840QM
MM# | Part number | S-Spec
909672 = FF8062700834801 SR013
909674 = FF8062700835900 SR015
909675 = FF8062700837004 SR016
909676 = FF8062700837100 SR017
910295 = FF8062700837101 SR02Z
910457 = FF8062700839305 SR045
910465 = FF8062700845306 SR04F
912297 = FF8062701078800 SR07D
912298 = FF8062701078900 SR07E
912299 = FF8062701079000 SR07F
912300 = FF8062701079100 SR07L
912301 = FF8062701079200 SR07M
915342 = FF8062700845307 SR0CG
915412 = FF8062700838117 SR0CJ
915413 = FF8062700838224 SR0CK
916676 = FF8062701078801 SR0DV
916677 = FF8062701078901 SR0DW
916678 = FF8062701079001 SR0DX
916679 = FF8062701079101 SR0DY
916680 = FF8062701079201 SR0DZ
916685 = FF8062701083401 SR0E4
916686 = FF8062701083501 SR0E5
916687 = FF8062701083701 SR0E6
916688 = FF8062701083801 SR0E7
916689 = FF8062701083901 SR0E8
916705 = FF8062701071601 SR0EQ
916707 = FF8062701076701 SR0ES
916708 = FF8062701076801 SR0ET
916709 = FF8062701076901 SR0EU
916710 = FF8062701077001 SR0EV
916699 = FF8062700848401 SR0EJ
917739 = FF8062701071000 SR0G8
917742 = FF8062701121900 SR0GB
917751 = FF8062701122400 SR0GE
917759 = FF8062701160300 SR0GJ
921414 = FF8062701275300 SR0TE
919323 = FF8062701186600 SR0LV
918108 = FF8062700848402 SR0HN
918113 = FF8062701071602 SR0HT
918115 = FF8062701076702 SR0HV
918116 = FF8062701076802 SR0HW
918117 = FF8062701076902 SR0HX
918118 = FF8062701077002 SR0HY
920173 = FF8062701083402 SR0Q3
920174 = FF8062701083502 SR0Q4
920175 = FF8062701083702 SR0Q5
920182 = FF8062701083802 SR0Q8
920183 = FF8062701083902 SR0Q9
918120 = FF8062701186900 SR0J0
918124 = FF8062701072101 SR0J4
918125 = FF8062701072201 SR0J5
918126 = FF8062701072301 SR0J6
918127 = FF8062701072401 SR0J7
918128 = FF8062701072501 SR0J8
Possibly: B790, B795, B860, B870, B890, B930, B980P, or B990
922751 = AW8063801033601 SR0VP
918114 = FF8062701076602 SR0HU
918112 = FF8062701071502 SR0HS
918109 = FF8062700848502 SR0HP
916706 = FF8062701076601 SR0ER
916704 = FF8062701071501 SR0EP
916702 = FF8062700848701 SR0EM
916701 = FF8062700848601 SR0EL
916700 = FF8062700848501 SR0EK
916681 = FF8062701079301 SR0E0
916682 = FF8062701079401 SR0E1
916683 = FF8062701083201 SR0E2
916684 = FF8062701083301 SR0E3
920172 = FF8062701083302 SR0Q2
920171 = FF8062701083202 SR0Q1
916675 = FF8062701078701 SR0DU
916690 = FF8062701084001 SR0E9
912303 = FF8062701079400 SR07P
912302 = FF8062701079300 SR07N
912296 = FF8062701078700 SR07C
912295 = FF8062701078600 SR07B
912294 = FF8062701078500 SR07A
Yonah - PCN106635-00
LF80539GF0412ME SL9JG Core Duo T2500E
LF80539GF0342ME SL9JF Core Duo T2400E
LF80539GE0252ME SL9JH Core Duo T2050
LF80538GE0462ME SL9ST Core Solo T1550
LF80538GF0412ME SL9L6 Core Solo T1500
LF80538GE0412ME SL9L3 Core Solo T1450
LF80538GE0362ME SL9L2 Core Solo T1350
Prescott - PCN108934-00 (all, in QDMS) & PCN106635-00 (SL8K3, in PCN)
• NE80546PG0961MM, SL8K5, Pentium 4 HT 3.4 GHz
• RK80546PG0961MM, SL8K5, Pentium 4 HT 3.4 GHz
• NE80546PG0881MM, SL8K3, Pentium 4 HT 3.2 GHz
• RK80546PG0881MM, SL8K3, Pentium 4 HT 3.2 GHz
LGA775 Prescotts with EM64T are assigned part numbers ending with an additional M, such as JM80547PG1121MM for the 571. Assuming Socket 775's part number scheme applies to Socket 478, there's a possibility that SL8K3 and SL8K5 have EM64T enabled. If these two S-Specs do exist, that would add two more EM64T-enabled S-Specs on Socket 478, along with SL7L7, SL7QB, and SL7Q8.
<DRNG product list>
Atom P6000/C6000 product list - https://csrc.nist.gov/CSRC/media/projects/cryptographic-module-validation-program/documents/entropy/E71_PublicUse.pdf
Coffee Lake-S (Refresh) product list - https://csrc.nist.gov/CSRC/media/projects/cryptographic-module-validation-program/documents/entropy/E232_PublicUse.pdf
Xeon D-2100 product list - https://csrc.nist.gov/CSRC/media/projects/cryptographic-module-validation-program/documents/entropy/E123_PublicUse.pdf
Xeon D-2100 part number and S-Specs - https://d2pgu9s4sfmw1s.cloudfront.net/UAM/Prod/Done/a06Hu00001icXJ1IAM/c9f399d5-af0c-2431-4058-8df3b0ac9417?response-content-disposition=inline%3Bfilename*%3DUTF-8%27%27PCN846911-00.pdf&Expires=2056479213&Key-Pair-Id=APKAJKRNIMMSNYXST6UA&Signature=Go5zPUNH0qncCKKYNrbWtoirTUMnWExFZgmEfpkY1F0TtosWxeu~dWNkDC560IGhUjQXcnNfyZnXkNeEEaQZ9vNoxRqnJeXM-G3WAW-mi1zR4WMkoxuprYwB6aML5M9DeBJby2nnHOH4B4jphgYEPWuRfSUmPkIcTH7DyAxBPhv9TnEXs9ZdguIq7fYCC9y0GsgcwGRjiaPg6DY2KwruOMSyJT5r4frc7y4czjnhb1oxhRDKfqW9WGhni6zRYcl5ZnxmkVwjJ~miGUjKpXwjy8yHxJatzDrvGY-ip~CANyHT-Q8gpFXQ1dhsIEaRPkcig2Az62JvYUYkQjZM6Yz9wA__
Xeon 2~3 product list - https://csrc.nist.gov/CSRC/media/projects/cryptographic-module-validation-program/documents/entropy/E69_PublicUse.pdf
Xeon 4 product list - https://csrc.nist.gov/CSRC/media/projects/cryptographic-module-validation-program/documents/entropy/E233_PublicUse.pdf
Xeon 6-B product list - https://csrc.nist.gov/CSRC/media/projects/cryptographic-module-validation-program/documents/entropy/E306_PublicUse.pdf
Xeon 6 product list - https://www.intel.com/content/www/us/en/content-details/832851/intel-xeon-processors-6944p-6960p-6972p-6979p-6980p-and-6952p.html
<Datasheets & specification updates list>
Links that are not from Intel means the original link has been removed or it's no longer available for public access. Some still remain available, but that might change. If the links from Intel no longer work, try using web.archive.org to access it.
Chipsets
Datasheets
D15343-003 - Intel® 82854 Graphics Memory Controller Hub (GMCH)
https://web.archive.org/web/20140513123949/http://download.intel.com/design/celect/854/D1534303.pdf
Specification updates
Processors
Datasheets, mobile
250686-007 - Mobile Intel Pentium 4 Processor-M (Northwood)
https://download.intel.com/design/mobile/datashts/25068607.pdf
Datasheets, desktop
243658-020 - Intel® Celeron® Processor up to 1.10 GHz (Covington, Mendocino, Coppermine)
https://www.intel.com/design/celeron/datashts/24365820.pdf
298596-004 - Intel® Celeron® Processor for the PGA370 Socket up to 1.40 GHz on 0.13 Micron Process (Tualatin)
https://web.archive.org/web/20060820190359/https://www.intel.com/design/celeron/datashts/29859604.pdf
244452-009 - Intel® Pentium® III Processor for the SC242 at 450 MHz to 1.0 GHz (Katmai, Coppermine)
https://web.archive.org/web/20160327230039/https://download.intel.com/design/PentiumIII/datashts/24445209.pdf
245264-008 - Pentium® III Processor for the PGA370 Socket at 500 MHz to 1.13 GHz (Coppermine)
https://download.intel.com/design/PentiumIII/datashts/24526408.pdf
249657-004 - Intel® Pentium® III Processor with 512KB L2 Cache at 1.13GHz to 1.40GHz (Tualatin)
https://datasheets.chipdb.org/Intel/x86/Pentium%20III/24965704.pdf (originally from http://download.intel.com/design/pentiumiii/datashts/24965704.pdf, unavailable)
249198-005 - Intel® Pentium® 4 Processor in the 423-pin Package (Willamette)
https://web.archive.org/web/20090316090539/http://download.intel.com/design/Pentium4/datashts/24919805.pdf
249887-003 - Intel® Pentium® 4 Processor in the 478-pin Package (Willamette)
https://web.archive.org/web/20160506225101/http://download.intel.com/design/Pentium4/datashts/24988703.pdf
298643-012 - Intel® Pentium® 4 Processor with 512-KB L2 Cache on 0.13 Micron Process and Intel® Pentium® 4 Processor Extreme Edition Supporting Hyper-Threading Technology (Northwood, Gallatin)
https://download.intel.com/design/Pentium4/datashts/29864312.pdf
300561-003 - Intel(R) Pentium(R) 4 Processor on 90 nm Process (Prescott)
https://download.intel.com/design/Pentium4/datashts/30056103.pdf
302351-004 - Intel® Pentium® 4 Processors 570/571, 560/561, 550/551, 540/541, 530/531 and 520/521∆ Supporting Hyper-Threading Technology (Prescott)
https://web.archive.org/web/20160304122036/http://download.intel.com/design/Pentium4/datashts/30235104.pdf
306382-003 - Intel® Pentium® 4 processor 6xx sequence, and Intel® Pentium® 4 processor Extreme Edition on 90 nm process in the 775-land package (Prescott-2M)
https://www.intel.com/Assets/PDF/datasheet/306382.pdf
Datasheets, server
302355-001 - Intel® Xeon™ Processor with 800 MHz System Bus (Nocona)
https://web.archive.org/web/20080224053056/http://download.intel.com/design/Xeon/datashts/30235501.pdf
306249-002 - 64-bit Intel® Xeon™ Processor with 2 MB L2 Cache (Irwindale)
https://www.intel.co.id/content/dam/doc/datasheet/64-bit-xeon-2mb-l2-cache-datasheet.pdf
Specification updates, mobile
250721-037 - Mobile Intel® Pentium® 4 Processor-M (Northwood)
https://web.archive.org/web/20171225190558/https://download.intel.com/design/intarch/specupdt/25072137.pdf
Specification updates, desktop
243748-051 - Intel® Celeron® Processor Specification Update (Covington, Mendocino, Coppermine, Tualatin)
https://cdrdv2-public.intel.com/841313/243749.pdf & https://www.pcrebuilding.altervista.org/9/download/56b4ac31be918_243748-053_Intel_Celeron_Specification_Update.pdf (newest, 243748-053)
244453-055 - Intel® Pentium® III Processor Specification Update (Katmai, Coppermine, Tualatin)
https://web.archive.org/web/20080224005351/http://download.intel.com/support/processors/pentiumiii/sb/24445355.pdf
249199-071 - Intel® Pentium® 4 Processor (Willamette, Northwood, Gallatin)
https://web.archive.org/web/20170830071658/http://download.intel.com/design/intarch/specupdt/24919969.pdf
302352-031 - Intel® Pentium® 4 Processor on 90 nm Process (Prescott, Prescott-2M)
https://www.intel.com/Assets/PDF/specupdate/302352.pdf & http://application-notes.digchip.com/027/27-45772.pdf (newest, 302352-033)
310309-012 - Intel® Pentium® 4 Processor 6x1Δ Sequence (Cedar Mill)
https://www.intel.com/Assets/PDF/specupdate/310309.pdf
Specification updates, server
302402-022 - 64-bit Intel® Xeon® Processor with 800 MHz System Bus (1 MB and 2 MB L2 Cache Versions) (Nocona, Irwindale)
https://www.intel.com/content/dam/support/us/en/documents/processors/xeon/sb/302402.pdf _________________ CPU-World: Errors & Updates - https://www.cpu-world.com/forum/viewtopic.php?t=26667
Intel & AMD QS/ES Details - https://www.cpu-world.com/forum/viewtopic.php?t=36609
Info about rate limits on CPU-World - https://www.cpu-world.com/info/site/pv_limit.html
Wasmachineman_NL
Posted: Tue Dec 29, 2020 2:44 pm Post subject: |
| That 2560M almost looks like a 32nm version of the i5-3340M, interesting segmentation by Intel. |
