extra HP part numbers for processors
PostPosted: Wed Dec 10, 2008 11:31 am    Post subject: extra HP part numbers for processors Reply with quote
some HP part numbers that can b added to the HP parts page (some r already in the list) http://www.cpu-world.com/info/HP-parts.html
ONLY part numbers verified off the HP site i will add to this list
1820-2298 IC - Z80A CPU (Z8400A)
1820-2299 IC - Z80A DMA (Z8410A)
1820-2300 IC - Z80A SIO/2 (z8442A)
1820-2301 IC - Z80A CTC
1820-3754 80286 processor IC - 8MHz
1820-5601M 80286 processor IC - 12MHz
1820-5643 80386 processor IC - 20MHz
1820-5829 80387 co-processor IC - 16MHz
1820-6054 80386 processor IC - 20MHz
1820-6294 80386 processor IC - 25MHz
1820-6295 80387 co-processor IC - 25MHz - Works in systems 16 to 25MHz
1820-6344 80287 co-processor IC - 12MHz
1820-6749 80486 processor IC - 25MHz
1821-0303 80486DX2 - Processor IC - 50MHz
1821-0304 80486SX - Processor IC - 25MHz
1821-0859 80486DX2 - Processor IC - 66MHz - Includes heatsink
1821-1168 80486DX2 - Processor IC - 66MHz - Does NOT include heat sink
1821-1285 486/100 - Processor IC (100MHz)
1821-1734 Intel Pentium processor - 66MHz
1821-2294 Intel Pentium processor - 100MHz (P54)
1821-2295 Intel Pentium processor - 133MHz
1821-2604 Intel Pentium processor - 166MHz (P54C) - Does NOT include heatsink
1821-3449 Intel Pentium Pro processor - 200MHz (P6, 256KB Level-2 cache) - Does not include heat sink
1821-3450 Intel Pentium Pro processor - 180MHz (P6, 256KB Level-2 cache) - Does not include heat sink
1821-3451 Intel Pentium Pro processor - 166MHz (P6, 512KB Level-2 cache) - Does not include heat sink
1821-3452 Intel Pentium Pro processor - 200MHz (P6, 512KB Level-2 cache) - Does not include heat sink
1821-3642 PROCESSOR PENTIUM PRO 200MHz 1MB CACHE
1821-3660 Intel Pentium MMX processor module - 233MHz
1821-3660-HPD Intel Pentium MMX processor module - 233MHz
1821-3820 CPU, PII 266MHZ
1821-3820-HPD Intel Pentium II processor module - 266MHz (Klamath, 512k Level 2 cache)
1821-3846-HPD IC PENTIUM
1821-4133 PII 300MHZ PROCESSOR (SL2W8)
1821-4201-HPD Intel Pentium II procesor - 350MHz (Slot 1, ECC, 512k Level 2 cache)
1821-4202-HPD Intel Pentium II procesor - 400MHz (Slot 1, ECC, 512k Level 2 cache)
1821-4203-HPD Intel Pentium II procesor - 450MHz (Slot 1, ECC, 512k Level 2 cache)
1821-4302 PII/266MMX PROCESSOR MODULE
1821-4303 LAPTOP PCBA PROC 233P II
1821-4304 LAPTOP PCBA PROC 266 MHZ P II
1821-4465 Intel Celeron processor module - 300MHz
1821-4482 AMD K6-266 ORDER 5064-6985-HPD Processor
1821-4486 PCBA PROCESSOR MODULE 300MHz PENTIUM II FOR OB2100
1821-4487 PII/300MHZ PROCESSOR MODULE INTEL
1821-4608 Intel Pentium II processor - 350MHz (Deschutes, 100MHz front side bus, 512KB Level-2 cache, Slot 1) Replacement for part 1821-4201
1821-4833 PCBA OMNIBOOK 900 PENTIUM II 300MHz
1821-4834 PII/366 256K Mobile PROCESSOR
1821-4863-GPC Compaq Pentium II 350 MHz 512 100 SI CPU
1821-4932 P333 MHZ PROCESSOR 4150
1821-4933 366MHZ INTEL MOBILE PII PROCESSOR
1821-5094-GPC HP/Intel PIII 500Mhz/512K/100 S2 CPU
1821-5143-NSD CPU PIII Xeon 550/100/51 CPU PIII Xeon 550/100/512KB
1821-5144-NSD CPU PIII Xeon 550/100/1M CPU PIII Xeon 550/100/1MB
1821-5145-NSD CPU PIII Xeon 550/100/2M CPU PIII Xeon 550/100/2MB
1821-5204 PROCESSOR PENTIUM II MOBILE 400MHz FOR OB4150/4150B
1821-5317 Compaq Intel PII 400/256 SL3JW CPU
1821-5380-GPC HP/Intel PIII 600Mhz/512K/133Bus CPU
1821-5414 500MHZ PROCESSOR
1821-5416 PROCESSOR PENTIUM III MOBILE 500MHz uPGA
1821-5688 600MHZ PROCESSOR, OB6000
1821-5689 650MHz PROCESSOR
1821-5690 PIII 700 MHZ MOBILE CPU
1821-5809-NSD PIII 850/100 CPU ORDER 1821-8667-NSD
1821-5826-NSD CPU 800MHz/133
1821-7552 K6 2/333 ORDER 1821-7552-HPD Processor
1821-8570 PIII800 PRC 256K MICRO PGA
1821-8621-NSD CPU XEON PIII 700/1M CPU XEON PIII 700/1M
1821-8692-NSD PIII 1000/133 MH Process PIII 1000/133 MH Processor
1821-8971-NSD CPU 800MHz/133 DO CPU 800MHz/133 DO
1821-8973-NSD CPU 933MHz/133 DO CPU 933MHz/133 DO
1822-0083-NSD CPU CELERON 900 MHz
1822-0085-NSD CPU CELERON 850 MHz
1822-0169-NSD CPU 700MHz/1MB LV CPU 700MHz/1MB LV
1822-0171-NSD CPU 700MHz/2MB LV
1822-0390-NSD PIII SVR TUAL 1.13G/512K
1822-0391-NSD PIII SVR Tual 1.26G/512K
1822-0497 AMD DURON 850 PROCESSOR
1822-0531-NSD tc2100 Celeron 950mhz tc2100 Celeron 950mhz
1822-0532-GPC P4 - 1500/400 Soc WD ste P4 - 1500/400 Soc WD step
1822-0566-NSD CPU 1.2GHz
1822-0572-NSD 2.0GHz CPU NW400 2.0GHz CPU NW400
1822-0675-NSD 1.4GHZ/512K TUALATIN C 1.4GHZ/512K TUALATIN C
1822-0704 AMD Duron processor - 1.0GHz (PGA)
1822-0858-NSD 1.2GHZ CELERON CPU 1.2GHZ CELERON CPU
1822-0905 INTEL CELERON 1.33GHZ 256K CPU
1822-0970-NSD CPU PIII 1.13GHZ B1 STEP CPU PIII 1.13GHZ B1 STEPPING
1822-0971-NSD CPU PIII 1.26GHZ B1 STEP CPU PIII 1.26GHZ B1 STEPPING
1822-1048-NSD NORTHWOOD 2.0GHZ CPU ASS NORTHWOOD 2.0GHZ CPU ASSY
1837-4608 PII 350 PROCESSOR
5064-0246 Intel Pentium processor - 200MHz (P54C) - Does NOT include heat sink
5064-0283 Intel Pentium processor - 166MHz (P54) - Does NOT include heat sink
5064-0298 Intel Pentium Pro processor - 200MHz (P6, 512KB Level-2 cache)
5064-1804 Intel Pentium Pro processor - 180MHz (P6, 256KB Level-2 cache)
5064-1805 Intel Pentium Pro processor - 200MHz (P6, 256KB Level-2 cache)
5064-1819 Intel Pentium MMX processor - 166MHz (P55C) - Does NOT include heat sink
5064-1820 Intel Pentium MMX processor - 200MHz (P55C) - Does NOT include heat sink
5065-0369-HPD Intel Celron processor module - 500MHz, 370 pin
5065-0403 Intel Pentium III processor - 450MHz (Katmai, 100MHz front side bus, 512KB Level-2 cache, SECC-2, Slot 1)
5065-0477 Intel Celeron processor - 500MHz (Mendocino, 66MHz front side bus, 128KB Level-2 cache, Socket 370)
5065-0932-HPD Intel Pentium III processor - 600MHz (Katmai, 100MHz FSB, 512k L2 cache, SECC-2 package)
5065-1310-HPD AMD K6-2 processor - 500MHz, (Chomper), 2.2v/3.3v split vcore
5066-0022-HPD Intel Pentium 4 processor - 1.6GHz (400MHz front side bus, mPGA478(w))
5066-0024-HPD Intel Pentium 4 processor - 1.8GHz (400MHz front side bus, mPGA478(w))
5066-0025-HPD Intel Pentium 4 processor - 1.9GHz (400MHz front side bus, mPGA 478)
5066-0026-HPD Intel Pentium 4 processor - 2.0GHz (400MHz front side bus, mPGA478(w))
5069-3537-HPD Intel Pentium 4 processor - 2.0GHz (Northwood, 400MHz front side bus, 512k Level 2 cache, MPGA478)
5069-4654-HPD AMD XP2600+ processor - 2.133GHz (266MHz front side bus)
PostPosted: Wed Dec 10, 2008 12:10 pm    Post subject: Reply with quote
Nice list, thanks for sharing it!
donutty
PostPosted: Wed Dec 10, 2008 12:55 pm    Post subject: Reply with quote
And thanks to HP too for making it so bloody difficult!
PostPosted: Thu Dec 11, 2008 8:36 pm    Post subject: Reply with quote
more added to the list
The alpha code added to the end of some of the part numbers is for the following (i think Laughing )
NSD >> server spares (90% sure on this)
HPD >> long term spare part (75% sure on this)
GPC >> no idea on this one Confused
Unconfirmed HP part Numbers
1820-7615 Intel 486 DX-33 MHz CPU (A80486DX-33)
1821-2378 HP/Intel P6/166
1821-2528 INTEL PENTIUM PRO PROCESSOR - 200MHZ (P6 256KB LEVEL-2 CACHE)
1821-5399 Intel Mobile Celeron processor - 466MHz (uPGA1)
1821-5400 Intel Mobile Celeron processor - 433MHz (uPGA1)
1821-5413 Intel Mobile Pentium III processor - 450MHz (C2)
1821-5415 Intel Mobile Pentium III processor - 450MHz (uPGA)
1821-5682 Intel Mobile Pentium III processor - 650MHz (MMC2)
1821-5684 Intel Mobile Celeron processor - 450MHz (MMC2)
1821-5687 INTEL MOBILE CELERON PROCESSOR - 500MHZ (UPGA2)
1821-5866 Intel Mobile Celeron processor - 600MHz (uPGA2)
1821-5867 Intel Mobile Celeron processor - 650MHz (uPGA2)
1821-8568 550MHZ AMD K6/2+ PROCESSOR MODULE
1821-8569 Intel Mobile Pentium III processor - 750MHz (uPGA)
1821-8571 Intel Mobile Pentium III processor - 850/700MHz (Coppermine SpeedStep 256K L2 cache uPGA2)
1821-8825 Intel Mobile Celeron processor - 700MHz (uPGA2)
1821-8826 Intel Mobile Celeron processor - 750MHz (uPGA2)
1822-0099 Intel Mobile Pentium III processor - 1.0GHz (uPGA2)
1822-0139 X2K P4 / 1.4GHZ 256K 400MHZ -SL4WS PROC
1822-0257 AMD Athlon processor - 900MHz (PGA)
1822-0259 AMD Athlon processor - 1.0GHz (PGA)
1822-0346 INTEL MOBILE CELERON PROCESSOR - 800MHZ (UPGA2)
1822-0365-GPC - Socket 478 P4 2.0Ghz
1822-0393 Intel Mobile Pentium III-M processor - 1.06GHz (Tualatin 133MHz front side bus 512KB L2 cache uFCBGA 0.13u RJ80530GZ004512)
1822-0399 - INTEL MOBILE PENTIUM III-M PROCESSOR - 866MHZ (TUALATIN 133MHZ
1822-0548 Intel Mobile Celeron processor - 800MHz (Tualatin 133MHz front side bus 128KB L2 cache uFCBGA 0.18u KW80533NZ800128)
1822-0582 AMD Athlon processor - 1.1GHz (PGA)
1822-0583 Intel Mobile Pentium III-M processor - 1.20GHz (Tualatin 133MHz front side bus 512KB L2 cache uFCPGA 0.13u RH80530GZ009512)
1822-0620 Intel Mobile Celeron processor - 933MHz (Tualatin 133MHz front side bus 128KB L2 cache uFCPGA 0.18u RH80533NZ933128)
1822-0692 CPU CEL-T 1.13 GHZ
1822-0693 CPU CEL-T 1.2 GHZ
1822-0778 Intel Mobile Pentium 4-M processor - 1.40GHz (Northwood 400MHz front side bus 512KB L2 cache uFCPGA 0.13u RH80532GC017512)
1822-0779 Intel Mobile Pentium 4-M processor - 1.50GHz (Northwood 400MHz front side bus 512KB L2 cache uFCPGA 0.13u RH80532GC021512)
1822-0780 Intel Mobile Pentium 4-M processor - 1.60GHz (Northwood 400MHz front side bus 512KB Level-2 cache FC-PGA2 478-pin)
1822-0781 Intel Mobile Pentium 4-M processor - 1.70GHz (Northwood 400MHz front side bus 512KB L2 cache uFCPGA 0.13u RH80532GC029512)
1822-0791 AMD Athlon XP1500+ processor - 1.30GHz
1822-0819 Intel Mobile Pentium 4-M processor - 1.80GHz (Northwood 400MHz front side bus 512KB Level-2 cache FC-PGA2 478-pin)
1822-0854 AMD Athlon XP1800+ processor - 1.50GHz
1822-0917 Intel Mobile Pentium 4-M processor - 1.60GHz (Northwood 400MHz front side bus 512KB L2 cache uFCPGA2 0.13u RH80532NC025512)
1822-0989 Intel Mobile Celeron processor - 1.60GHz (Northwood 400MHz front side bus 256KB L2 cache uFCPGA2 0.13u RH80532NC025256)
1822-1024 Intel Mobile Celeron processor - 1.50GHz (Northwood 400MHz front side bus 256KB L2 cache uFCPGA2 0.13u RH80532NC021256)
1822-1050-NSD P4 2.4 GHZ 400 MHZ C1
5063-4583 486 50MHZ DX2-SL Processor (printer part)
5063-4584 Intel 486DX2-66 SL 66Mhz CPU
5063-5606 350MHz Pentium II Processor Module - with 512K Level 2 Cache
5063-7022 Pentium 75MHz VCC CPU
5063-7024 Intel Pentium 100MHz CPU A80502-100
5063-7058 Intel VCC C2 54C/ 75MHz Pentium SX961 CPU
5063-7089 Intel SX994 Pentium
5063-7089 Intel SX994 Pentium P54C/133CS 120Mhz CPU
5063-7974 Pentium-133Mhz CPU P54/133CS
5063-8791 Intel Pentium Pro 150MHz 256K CPU SY010
5063-9019 150MHz P54C CPU 5063-9019
5064-2651 PROCESSOR MODULE 233MHZ PENTIUM II
5064-2652 PROCESSOR P2 266 MHZ
5064-2656 CPU 233MHZ PENT
5064-3697 PROCESSOR MODULE 333MHZ PENTIUM II
5064-7452 CPU Celeron 300A with Heatsink
5064-9130 Celeron 400-370P CPU
5064-9703 Intel PII Slot 1 SL357 With Heastsink & Fan SL357
5183-3423 200MHz Pentium Pro Processor (with 512k Internal Cache)
PostPosted: Thu Dec 11, 2008 10:46 pm    Post subject: Reply with quote
Thanks for the list! I will add these next week.
pinkie
PostPosted: Fri Dec 12, 2008 5:55 am    Post subject: Reply with quote
Thanks for sharing the list! Smile
Yan
iguana
PostPosted: Fri Dec 12, 2008 7:02 am    Post subject: Reply with quote
This is the most useful offtopic Smile
My Want List: http://www.cpu-world.com/forum/viewtopic.php?t=22729
Soviet chips info and my own collection: www.cpu-ukraine.com
PostPosted: Fri Dec 12, 2008 9:33 am    Post subject: Reply with quote
added more part numbers and separated into a confirmed (against HP parts store) list and unconfirmed list. Very Happy Very Happy
tlccomp
PostPosted: Fri Dec 12, 2008 4:47 pm    Post subject: Reply with quote
I have two HP parts that I'm trying to ID.Sad Both are from older SCSI drives.
1821-0809 & 1821-0966, 68 Pin PLCC's, Date codes between 1992 and 1994, Intel copyright.
I have other SCSI drives from that era with 80C186, 80C188 and 80C196 they all look the same.
The two most common elements on Earth are oxygen and stupidity.
PostPosted: Mon Dec 15, 2008 7:57 pm    Post subject: Reply with quote
thats about all the old series HP part numbers (xxxx-xxxx) ive come across and could verify against HP. Shocked
If i come across any more i will edit this post to add them and not to the existing lists Very Happy
cheers
Stu
PostPosted: Tue Dec 16, 2008 1:18 pm    Post subject: Reply with quote
The list is very informative.
Do you perhaps have some data about 1TW5-0501 ?
It's a 486-sized unknown PGA chip.
PostPosted: Tue Dec 16, 2008 6:17 pm    Post subject: Reply with quote
It is most likely a (IOP) IO processor for a HP 800 SERIES G60 (also the X60) CPU BOARD (HP Part number A2982-60001)
Here is a board for sale
http://cgi.ebay.com/HP-A2362-60001CPU-Card-A-3448-GT-1TW5-0501A1703-80094_W0QQitemZ140159429754QQihZ004QQcategoryZ4193QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
It also present on the HP 9000 Series Processor board (HP Part Number A2982-69201) http://www.alancomputech.com/a2982-69201.html
Have a look at this thread about of an equivalent chip from a HP 1000 system
http://www.cpu-world.com/forum/viewtopic.php?t=10858
schoeneweide
PostPosted: Thu Dec 18, 2008 3:55 pm    Post subject: Reply with quote
i found further HP house numbers for some old microprocessors:
http://howto.wikia.com/wiki/Howto_identify_integrated_circuit_(IC)_functions_from_their_Hewlett_Packard_(HP)_number
PostPosted: Thu Dec 18, 2008 6:08 pm    Post subject: Reply with quote
just found the list here is far less complete Smile
My vintage CPU collection:www.cpumuseum.com
Chinese Forum: http://www.cpumuseum.com/forum
PostPosted: Thu Dec 18, 2008 10:06 pm    Post subject: Reply with quote
The list was originally intended just for collectors, so it includes only microprocessors and microcontrollers.
