What are these slots for sony vaio vpcs13x9r (pcg-51111v) ?
zbugz
PostPosted: Mon May 06, 2024 5:49 am    Post subject: What are these slots for sony vaio vpcs13x9r (pcg-51111v) ? Reply with quote
Hi All ! I have sony vaio vpcs13x9r (pcg-51111v)
What are these slots (1 and 2) for?
rjluna2
PostPosted: Mon May 06, 2024 6:46 am    Post subject: Reply with quote
I think:
1) PC Bus card slot.
2) Mini SATA Solid State Drive
zbugz
PostPosted: Mon May 06, 2024 11:08 am    Post subject: Reply with quote
rjluna2 wrote:
I think:
1. Can I insert a 3g modem into this slot
Calbris
PostPosted: Mon May 06, 2024 11:08 am    Post subject: Re: What are these slots for sony vaio vpcs13x9r (pcg-51111v Reply with quote
1) ExpressCard/34 cards. It's an old expansion slot, something like the BC628 could fit in there to provide two USB 3.0 ports.
2) Full-size MiniPCI Express cards with a USB 2.0 interface, such as the Qualcomm Gobi 2000 modem. These are not PCI Express cards, they are actually USB 2.0 cards in a MiniPCI Express form factor.
The other side of your Vaio's motherboard has a half-size MiniPCI Express card slot with a PCI Express 2.0 interface. I believe that is where your Wi-Fi card is located.
CPU-World: Errors & Updates - https://www.cpu-world.com/forum/viewtopic.php?t=26667
Intel & AMD QS/ES Details - https://www.cpu-world.com/forum/viewtopic.php?t=36609
Info about rate limits on CPU-World - https://www.cpu-world.com/info/site/pv_limit.html
Chriscosmo12
PostPosted: Mon May 06, 2024 11:16 am    Post subject: Reply with quote
EDIT: dang, I took way too much time to type up my message and others beat me to it. Here's my two cents at least:
Looking up the model I managed to find a manual. It appears (1) is an ExpressCard slot. It also seems that the laptop had a SIM card option, so (2) could be for a mobile network module, or I've seen it be used for Bluetooth, but there is no antenna nearby for wireless signal. (2) could just be for an optional mSATA SSD cache in this case, as I've seen laptops from this era also come with those.
My Collection Archive
zbugz
PostPosted: Mon May 06, 2024 11:31 am    Post subject: Reply with quote
The laptop has Bluetooth.
zbugz
PostPosted: Mon May 06, 2024 11:33 am    Post subject: Re: What are these slots for sony vaio vpcs13x9r (pcg-51111v Reply with quote
How activate 3g modem ?
The laptop has wifi 5 ghz
Calbris
PostPosted: Mon May 06, 2024 12:32 pm    Post subject: Re: What are these slots for sony vaio vpcs13x9r (pcg-51111v Reply with quote
Insert an Ericsson modem card or a Qualcomm Gobi modem card into the full-size MiniPCI Express card slot, or buy a USB 3G modem instead.
Both ways work, but you need to check if there is a Mini-SIM or a Micro-SIM card slot on the other side of the motherboard if you want to use a MiniPCI Express card modem. Check for the slot on the left, use this picture as a reference - https://thebusinessendonline.co.uk/cdn/shop/products/5f353e76e343aa4b70750321_1024x1024@2x.jpg?v=1599216831
If you don't have a SIM card slot, you must use a USB 3G modem.
zbugz
PostPosted: Mon May 06, 2024 2:53 pm    Post subject: Reply with quote
Ok, i'm chek it
mavroxur
PostPosted: Tue May 07, 2024 6:27 pm    Post subject: Reply with quote
As said above, one is Expresscard/34 and the other is Mini PCI
zbugz
PostPosted: Wed May 08, 2024 3:52 pm    Post subject: Reply with quote
I checked, there is a slot for the SIM card.
Do I need to insert a SIM card into the slot and buy a modem in the miniPCI Express card slot with an antenna?
I also put a miniPCI Express ssd drive there and it didn't work.
I also set jumper 2 and 4 to the on position. Is there a description of these jumpers?
P.S. Where can I get the latest bios for my laptop?
Calbris
PostPosted: Thu May 09, 2024 7:54 am    Post subject: Re: What are these slots for sony vaio vpcs13x9r (pcg-51111v Reply with quote
Yes and yes.
MiniSATA/mSATA SSDs will not work in MiniPCI Express slots with a USB 2.0 interface. They will work only if the MiniPCI Express slot has a SATA interface wired in, which your Vaio does not have.
It should be stated in the schematic, unfortunately I don't have it.
I believe this is the latest BIOS version available.
zbugz
PostPosted: Thu May 09, 2024 4:35 pm    Post subject: Reply with quote
Which modem should I buy for 4g ?
I also got a wimax after switching jumpers
Calbris
PostPosted: Thu May 09, 2024 7:19 pm    Post subject: Re: What are these slots for sony vaio vpcs13x9r (pcg-51111v Reply with quote
Sierra Wireless AirPrime MC7710, but you need 3 antennas instead of the usual 2. I think it supports the LTE bands in your country, so it should work.
zbugz
PostPosted: Fri May 10, 2024 5:10 am    Post subject: Reply with quote
There are three antenna outputs on this modem: main, GPS and aux. What is each antenna for? GPS is clear for what.
